RV.Net Open Roads Forum: Class A Motorhomes: weather pro awning
 > weather pro awning
larry barnhart
wenatchee. wa usa
Posted: 11/01/11 11:59am Link  |  Print  |  Notify Moderator
Neighbor has a weather pro awning and it wants to roll back in when it wants to or he makes it. anybody know the fix?
chevman
chevman
2001 35 ft avalon alpenlite RK
prodigy
easyrider/reese airhitch
trailair center point suspension
JT Strong Arm Stabilizers
KSH 55 inbed fuel tank
Garmin 2720
scanguage II
TD-EOC
Induction Overhaul Kit
TST tire monitors
tahiti16
Camarillo, CA
Posted: 11/01/11 12:06pm Link  |  Print  |  Notify Moderator
Seems to be one of two modes for these either they almost never roll up, like ours takes a lot of wind before it rolls up, or it rolls up at the slightest breeze, like a hummer going by to close to the sensor. Our sensor is on the roof I have heard the early ones the sensor was on the end of the roller. There is also a switch on the control box down in a bay that allows you to disable the auto feature while still allowing the inside or remote switch to work.
Ray, Cheryl, Cory & of course Miss Molly the four-legged child
2006 Dolphin 36' F53 V10 5 speed auto 2 slides 7.5 KW genset
Loren Ross
Reno, NV
Posted: 11/01/11 11:59pm Link  |  Print  |  Notify Moderator
Mine does the same thing. On the control box on mine, there is a little toggle switch on the side of the control box that will turn off the wind sensor.
J-Rooster
Port Orchard, Wa. / Lake Havasu City, Az.
Posted: 11/02/11 01:22am Link  |  Print  |  Notify Moderator
I also have a roof sensor, looks like a mushroom on top of the coach. There's also a weather pro awning adjuster box for mine in the storage compartment just under the awning.
CREATO
Beautiful Harvey N.D.
Posted: 11/01/11 08:00pm Link  |  Print  |  Notify Moderator
Our current 5ver has one it and is made by dometic. Ours has a sensor on the front arm of the roller. To disarm the auto retract function you press a couple buttons on the remote don't remember the sequence instructions are on the back of the remote switch. I would suspect a faulty sensor but would contact dometic to make sure.
I dont rent out space in my brain
