CR13
CA
What gauge extension cord do you use when plugging into the house to charge up the battery and run the fridge until you leave?
exeter_acres
North of Atlanta, GA
if those are the only things running...
then there is not much of a draw at all.. 16ga would probably be fine depending on length.
I use a 12ga and can run the air no problem
fla-gypsy
North Florida
I use a 12ga unless I am running the air.
skipnchar
Topeka or somewhere else
If the cord gets warm to the touch it's too light. If it gets hot it's dangerous.
Desert Captain
Tucson
Nothing less than 12 gauge and I don't run the air off of that. The 12 will run the air but the cord gets warm and less than full voltage can do serious damage to the AC unit. If I want to run the AC at home I fire up the two Honda 2000's and parallel them. They can always use a little work and it is a good way to burn the old gas out of them.
coolbreeze01
Redding, Ca
Same as the TT, 10-3.
2008 Dodge 3500 With a Really Strong Tractor Motor...........
LB, SRW, 4X4, 6-Speed Auto, 3.73, Prodigy P3, Blue Ox Sway Pro........
2007 Komfort 212 on 225 75R 15E Maxxis 8008 Tires.........
Turtle n Peeps
California
The biggest I can find in the store.
outside the fire"
We Cant Wait
Jamestown NY
We use the regular trl power cord and a 30-20Amp adapter to plug into a standard outlet.
Aluminum Siding
So Cal
12 guage up to 50 ft AC runs great. If I need to run the air past 50 ft 10 guage. If I go past 50 feet with a 12 guage the AC will struggle. I was told this can burun up the motor. When we dry camp I put my Champion Whisper Generator 100 feet away so I don't bug the neighbors late at night or stink em out. I use a 100 ft 12 guage no problems (no AC of course).
KD4UPL
Swoope, VA
For just charging the battery and the refrigerator most any cord will do. that's probably only about 3 or 4 amps total. 16 AWG is probably the smallest available in a 3 wire outdoor cord. It will work fine.
