RV.Net Open Roads Forum: Tech Issues: Sanitizing Water Line Hoses
 > Sanitizing Water Line Hoses
ernie1
Sacramento,California,USA
Posted: 11/08/11 10:04pm Link  |  Print  |  Notify Moderator
Salin'Shoes:
The phosphoric acid in Star San is not the active ingredient that makes this product a sanitizer. There has to be another sanitizing ingredient that is not listed in the company's literature. If their claim is that phosphoric acid is the sanitizer, be aware that that is not a product that is approved by any of the public health agencies for use to sanitize multiuse utensils in restaurants.
Starcraft 21550:
Phosphoric acid is not the active ingredient in a sanitizer. I am aware of the process of sanitizing dishes and similar materials since I am a retired health inspector with over 30 years experience. Please note: multi use utensils(dishes, etc.) are to be sanitized by washing with a detergent( most machines have soap with potassium hydroxide to help remove stuck on food); rinsing with clean water; sanitizer(bleach at 50ppm) and a rinse agent is sprayed on WITHOUT drying the dishes mechanically because that's what the rinse agent does.
Hope this doesn't get the original subject off track.
ejforwood
Littleton (Denver) Colorado
Posted: 11/09/11 02:04am Link  |  Print  |  Notify Moderator
Connect your hose to the inlet of your system. Pour the recommended amount of bleach for your fresh water tank's capacity into the other end of the hose using a funnel.
Connect the hose to your water faucet and add enough water to fill the rest of the hose. Let it set for a few minutes. Proceed to fill your fresh water tank and your entire system by opening each faucet and allowing the water to fill all the lines. You will be able to smell the bleach at each faucet. Let it set for 1 to 2 hours.
Open all faucets and run fresh water until the bleach smell goes away. You're done! You've sanitized your hose, the tank, and all the lines.
Now add a good filter and quit wasting money on bottled water. Not to mention all the plastic bottles you are putting into the landfills!
Sorry, I just had to add that!
Jerry & Dottie
98 Bounder 34V, 99 F-53 Ford V10 chassis
06 Saturn VUE 4I
computerbug
Sarasota
Posted: 11/09/11 04:19am Link  |  Print  |  Notify Moderator
I'm with Ejforwood This is real easy. I do this 4 or 5 times a yr. Cathie
Mr. Obvious
lexington
Posted: 11/09/11 04:47am Link  |  Print  |  Notify Moderator
I use the 12 volt pump I set up to fill the fresh water tank from jugs to pump some bleach/water through the hoses and let them sit full for awhile. Then pump some fresh water through and put away.
Starcraft21SSO
Atlanta, Ga.
Posted: 11/09/11 06:27am Link  |  Print  |  Notify Moderator
@Dutch - FWIW, we don't use bleach in beer brewing because the residue will actually get incorporated in the fermentation process and yield some very off sub-flavors. But fermentation is a very complex biological process, and that's very different from plain old drinking water.
The advantage of bleach is that it will kill bulk growth like mildew. The disadvantage is that it requires 5 minutes to be effective. It also needs to be rinsed off, which leaves the surfaces damp and ready for more growth
The advantage of starsan is that it requires just 30 seconds and needs no rinsing, thus continuing to protect the surfaces.
All that said, brewing/fermentation requires a near-sterile process and plain old drinking water hardly requires that level of attention.
2002 Starcraft TravelStar (21SSO) Hybrid TT
paulcardoza
Southeastern Massachusetts
Posted: 11/09/11 06:37am Link  |  Print  |  Notify Moderator
FW hose is one of the least expensive items we deal with. I replace mine every spring.....
Paul & Sandra
New Bedford, MA
2003 Monaco Executive M43 DS2
Dutch_12078
Great Sacandaga Lake, NY
Posted: 11/09/11 08:06am Link  |  Print  |  Notify Moderator
I never use a new fresh hose without sanitizing it first.
Dutch
Dutch
1995 Coachmen Catalina 322QBXL
F53 chassis, 460 V8, TST TPMS
Quadra Bigfoot EZE Levelers
Sailin' Shoes
Chapmansboro Tn
Posted: 11/09/11 07:08am Link  |  Print  |  Notify Moderator
HMMMMM, Brewing an Irish Stout in time for St Patrick's day AND cleaning the hoses to prep for the 2012 season sounds good to me! Think I'll give AG another whirl!
RV'n Web Blog
Dutch_12078
Posted: 11/09/11 08:05am Link  |  Print  |  Notify Moderator
No argument here, I'm looking into using Star San for my spring sanitizing.
