RV.Net Open Roads Forum: Travel Trailers: 'Furnace not starting
 > 'Furnace not starting
tocools
California
Posted: 11/11/11 06:35pm Link  |  Print  |  Notify Moderator
Our Furnace try's to fire but does not fire everytime the blower comes on but no heat after while it just shuts down. When it does fire it works great. Not sure what is going on.
We have a 2010 keystone Hideout
1999 F250 PSD
2010 Keystone Hideout 26RBS
mikem1945
Illinois
Posted: 11/11/11 06:40pm Link  |  Print  |  Notify Moderator
My first guess would be that the igniter is either out of position or the gap is set wrong and not giving you enough spark. Either are easy to fix except you may have to remove furnace to get to it. What brand is it?? Mostare either Atwood or Suburban.
MMiller
2005 Starwood SL 29ft RKS FW
2004 GMC 2500HD Ext Cab Duramax
padave
Richland PA
Posted: 11/11/11 07:45pm Link  |  Print  |  Notify Moderator
Should still be under warranty.....contact the manufacturer
wife and 2 daughters
2012 Ford F150 SCrew 4x4 Max Tow
2011 Lacrosse 318bhs
Equalizer
former:
Nissan Titan
Rockwood Roo 233
Coleman Westlake
AtomicChicken
Central Louisiana
Posted: 11/11/11 07:56pm Link  |  Print  |  Notify Moderator
Have you checked to see if the igniter is firing properly? There may be an observation window you can look through to see it firing.
2007 F-150
2006 Sun Valley RoadRunner 240BH
Prodigy P2 / EAZ-Lift WDH
tocools
California
Posted: 11/11/11 08:08pm Link  |  Print  |  Notify Moderator
It is a Suburban and there is no window to look thru it is completely closed in. I can pull out a drawer but it does not help much.
* This post was edited 11/11/11 08:39pm by tocools *
Teoma
Southwest Virginia
Posted: 11/11/11 08:43pm Link  |  Print  |  Notify Moderator
I had a circuit board go out on my 2010 Atwood furnace. Also sometimes he sail switch can go out.
Teoma
dks
Mississauga
Posted: 11/12/11 05:57am Link  |  Print  |  Notify Moderator
Is it possible your thermostat is not turned down enough?
QCMan
Grand Strand
Posted: 11/12/11 07:20am Link  |  Print  |  Notify Moderator
Have you checked the voltage to the board? Some igniters are more fussy about voltage than others.
Are the rest of the items that work on gas functioning normally?
2004 Starcraft Aruba 25RS, 2004 Dodge Dakota SLT extended cab. Just the two of us, a Jack and a desire to roam!
TPUC
TN
Posted: 11/12/11 07:21am Link  |  Print  |  Notify Moderator
Mine did this and it was a loose wire on the sail switch
bedell
Colorado
Posted: 11/12/11 03:47pm Link  |  Print  |  Notify Moderator
We had similar problem. Loose wire connections. The service tech replaced the factory installed crimp-on wire connectors with something more secure.
