RV.Net Open Roads Forum: Class A Motorhomes: Overflowing Toilet
 > Overflowing Toilet
revump
Las Vegas
Posted: 11/11/11 08:33pm Link  |  Print  |  Notify Moderator
On our 06 Alfa See Ya, water continues to run in the toilet after it has been flushed. The only way to stop it so far is to turn off the pump. It looks like all the valves are in the back. Any ideas.
Bob
crah
Las Vegas
Posted: 11/11/11 08:45pm Link  |  Print  |  Notify Moderator
Bob your type of toilet listed may help others troubleshooting better.
2003 Holiday Rambler Scepter 36PST 3 Slide
Cummins ISC 350/Side Radiator
Banks System
2011 Buick Enclave Towed
Ready Brute/Ready Brake/Blue Ox
skipnchar
Topeka or somewhere else
Posted: 11/11/11 09:06pm Link  |  Print  |  Notify Moderator
Replace the water module.
Jim & Betty
Brandon, South Dakota
Posted: 11/11/11 09:10pm Link  |  Print  |  Notify Moderator
Hi
I will try but I am going om memory and lately that has been short.
The toilet has a rubber type of band that holds a shell that wraps the lower part of the toilet. Remove the band, back of toilet, hold down the foot lever and remove the shell. That will expose the works there if I remember right you will probibly find a broken connector or spring, I think spring.
Also if you go over to the Alfa site on the yahoo forums someone there would be a better help than me on this subject.
JimR
Old-Biscuit
Across the USA
Posted: 11/11/11 09:16pm Link  |  Print  |  Notify Moderator
Check with Thetford.........they had some 'bad' water modules and would send replacements free.
Remove shell........disconnect water supply line and then remove water/vacuum breaker assembly......two screws IIRC....one holds return spring in place. Stubby Phillips screw driver
You can see the assembly on Thetford web........product manuals
revump
Las Vegas
Posted: 11/11/11 08:57pm Link  |  Print  |  Notify Moderator
Thetford Aqua-Magic STYLE PLUS
ArchHoagland
Clovis, CA, USA
Posted: 11/25/11 08:36am Link  |  Print  |  Notify Moderator
Help me out here. You mention "two screws IIRC" what does IIRC mean?
Thanks
2004 Monaco La Palma 36DBD
Workhorse W22 8.1 Gas Allison 1000, 7.1 mpg
US Gear Brakes
Nothing is either good or bad, but thinking makes it so.
americanrvcompany
Azusa, CA 91702
Posted: 11/24/11 02:12pm Link  |  Print  |  Notify Moderator
were you able to fix your toilet yet? If you have any questions, let me know. I can try to help you trouble shoot.
Jeff
Fleet Man
Western WA
Posted: 11/12/11 10:46am Link  |  Print  |  Notify Moderator
Replacing the leaking water valve is not difficult at all. You should be able to do it with the toilet in place, just by reaching behind it. I had to replace mine because it was leaking, it took me longer to round up the few tools needed than it took to remove and replace the valve.
2007 Winnebago Journey 34H
Toad, '08 Ford Taurus X
Blue OX, Aventa
US Gear UBS
Galvanizd
Looking at the Mogollon Rim ...... For a bit.
Posted: 11/13/11 09:57am Link  |  Print  |  Notify Moderator
Try this site
http://www.americanrvcompany.com/
Click on the "toilets" section
Find your toilet. The site has owners manuals and some of them list trouble shooting items. They also sell replacement parts.
Also, try giving them a call, they were helpful when my Sealand did the same as yours.
By the by, Mine is different that yours, but I took mine apart, cleaned up fittings and connections. found a loose connection and problem was solved.
We've always shut the shore water off and turn the pump off when we leave the rv for any length of time and was glad we did.
