RV.Net Open Roads Forum: Tech Issues: Oven pilot light
 > Oven pilot light
MauryFrench
Manvel, TX
Posted: 12/02/11 07:35pm Link  |  Print  |  Notify Moderator
Hello, all. I am going to hijack this thread a little. I have a 1990 Hitchhiker with a Wedgewood oven/range. Does this oven have a thermocouple in the pilot? I am not seeing it, at least seeing what looks like a standard thermo-coupler to me. I would love to light and leave the pilot but am somewhat superstitious.
Maury French
1990 Hitchhiker II 26 ft 5th Wheel.
tenbear
Northern Vermont, USA
Posted: 12/03/11 02:25pm Link  |  Print  |  Notify Moderator
pianotuna wrote:
Hi Skip,
Do you have to hold in the knob if you light off the main burner?
My pilot light is at the very back of the oven and I have not used it because of the necessity of getting on my hands and knees.
Don, Perhaps you have already seen this post, but in case you missed it maybe it would be of interest.
Class C, 2004/5 Four Winds Dutchman Express 28A, Chevy chassis
2010 Subaru Impreza Sedan
Camped in 45 states, 7 Provinces and 1 Territory
pianotuna
Regina, SK, Canada
Posted: 12/03/11 04:31pm Link  |  Print  |  Notify Moderator
Hi tenbear,
No, I had not seen that posting! Thanks very much.
Regards, Don
Kustom Koach Class C 28'5" 256 watts Unisolar, 875 amp hours in two battery banks 12 volt batteries, 2500 MSW watt inverter.
rvtroubles
AZ back yard
Posted: 01/25/12 09:42pm Link  |  Print  |  Notify Moderator
I also have similar problem.I have a Suburban range(I don't know if it is the same as the Magic Chef)
My problem is, the pilot lights,but with a very small flame,it doesn't touch the probe.The LP pressure is good,tried adjusting the small screw,it is at max.,made sure the knob goes all the way in,no kinks in tubing,took pilot assembly apart and cleaned.
Somewhere I read that when the knob is turned up the pilot becomes larger and causes the burner to go on.What would be the defective part?
I would appreciate your help,the stove works good ,and I don't want to replace it. Thanks
 > Oven pilot light
