RV.Net Open Roads Forum: Towing: Welding equalizer brackets to TT tongue?
Search only in Towing
Open Roads Forum  >  Towing
 > Welding equalizer brackets to TT tongue?
firetruckin
Pacific NW
Posted: 11/17/11 03:43pm Link  |  Print  |  Notify Moderator
Has anyone welded the "L" brackets of their equalizer hitch directily to the trailer tongue? I have been using the hitch for years and absolutely love it. I was just considering how nice it would be to eliminate the occasional tightening adjstments.
skipnchar
Topeka or somewhere else
Posted: 11/17/11 04:04pm Link  |  Print  |  Notify Moderator
Might have an effect on resale value. Not everyone uses that brand of WD hitch.
SoakedKarma
Reno neh-va-duh
Posted: 11/17/11 04:26pm Link  |  Print  |  Notify Moderator
Or weaken the frame a bit from the heat applied during welding
Itchey Feet
Wyoming
Posted: 11/17/11 04:56pm Link  |  Print  |  Notify Moderator
Or trade tow vehicles and hitch measurements are different on newer tv.
My feet are fine as long as they are traveling.
goducks10
Keizer OR
Posted: 11/17/11 07:04pm Link  |  Print  |  Notify Moderator
I have and have had no problems. I put a small 3/4" weld on the bracket that is bolted to the tongue. Welded up at the top of the bracket at the top of the tongue on the side. It can easily be removed with a diamond cutting wheel and then ground down smooth. That way you can keep you EQ hitch if you want when you sell the TT.
Earl E
Green Valley, AZ
Posted: 11/17/11 08:32pm Link  |  Print  |  Notify Moderator
Sounds like an easy fix. It would only take a tack weld and be easily removed when you sell.
2007 Northwoods Arctic Fox 32 5S Fifth Wheel-for sale now that we are not full-timing
2011 Keystone 23rks Hideout to poke around the smaller parks in the great Southwest
2007 Chevy Silverado 2500 HD Diesel
Prodigy brake control
chadsalt
GA
Posted: 11/17/11 09:24pm Link  |  Print  |  Notify Moderator
Drill a hole and bolt on just the "L" piece. A regular bolt and lock-nut/washer won't work loose like the set screw and bracket assembly.
firetruckin
Pacific NW
Posted: 11/19/11 11:45am Link  |  Print  |  Notify Moderator
I contacted equalizer and they have no issue with welding the brackets to the tongue. I'm not worried about the "permanent" mounting of the bracket. I just wondered if it had been done. I did find out that they have a new bracket out that may fit better but I think I'll just do the welding. Thanks for the replies.
SoCalDesertRider
SanDiego, CA, USA
Posted: 11/20/11 04:33am Link  |  Print  |  Notify Moderator
I have a Reese/Valley hitch but my brackets are welded on, all the way around. No problems with trailer or brackets.
05E350 6.0PSD
98Ranger
69Bronco ATC250R CR500
20' BigTex flatbed carhauler
Callen Camper
92F350 CrewCab 4x4 351/C6
HD Springs Bilsteins,
4.56's & LockRite rear
mike54
Crystal Lake,IL. GO BEARS
Posted: 11/22/11 11:53am Link  |  Print  |  Notify Moderator
I was thinking welding mine on too I'm tired of readjusting the brackets every trip.
Mike & Marsha
West Allis Sunshiners
Rockwood Signature Ultra Lite 8319SS
2005 dodge ram 3500 5.9 cummins diesel
