RV.Net Open Roads Forum: Stop Engine Light on Cummins ISB 6.7
 > Stop Engine Light on Cummins ISB 6.7
RTrider
London, Ontario, Canada
Posted: 11/23/11 08:38am Link  |  Print  |  Notify Moderator
Friend has the Stop Engine Light and about to start a 2000mile trip.
We changed oil as it was over due and the light went out on the way back from the garage. The light is on again this morning. Its about the mid 40's here this morning.
Looked at the manual and nothing mentioned.
Any suggestions or tips on resolving this as she needs to get on the road in the next couple of days.
Is there any way to get a fault code out of the computer. It is a 2008 Allegro with a Cummins ISB 6.7
Thanks?
2011 Jayco Eagle Super Lite 298RLS
2010 Chevy Silverado 3500HD Duramax Diesel LB/SRW
Equalizer Hitch, 1200 lb bars
2009 Kawasaki Vulcan Classic 900LT.
Rampage winch loader for bike in back of TV
Some Pictures
Fleet Man
Western WA
Posted: 11/23/11 08:43am Link  |  Print  |  Notify Moderator
Is the coach on a Freightliner chassis? Is it equipped with the Light Bar Control Unit (LBCU) on the dash. The diagnostics package in the LBCU may be able to isolate a code. Otherwise, a trip to a Cummins shop may be in order.
2007 Winnebago Journey 34H
Toad, '08 Ford Taurus X
Blue OX, Aventa
US Gear UBS
RTrider
Posted: 11/23/11 08:54am Link  |  Print  |  Notify Moderator
Yes it is a Freightliner chasis and it is equipped with a LBCU.
Looking for a way to retrieve the codes if available on the unit.
Thanks, Gary
MarcW
Tucson, Az.
Posted: 11/23/11 08:58am Link  |  Print  |  Notify Moderator
Check the coolent level. Low is one of the things that will turn on a stop engine. If not low it could be a bad sensor.
2007 Monaco Dynasty Emperor IV
2013 Jeep Wrangler Rubicon
RTrider
Posted: 11/23/11 09:15am Link  |  Print  |  Notify Moderator
The coolant level in the overflow tank is at the FULL.
The engine oil level was below ADD yesterday so we topped it up and drove 5 miles to have the oil and filters replaced and the the warning light went out on the drive back, and the engine oil level is at the FULL this morning.
The transmission oil level cold is well above the hot level. I have not checked the transmission level hot.
The motorhome has 11,500 miles on it.
RTrider
Posted: 11/23/11 09:25am Link  |  Print  |  Notify Moderator
We are parked in an RV park in Arizona City, AZ if anyone can recommend a mechanic we might call for help. Why do these things happen on long weekends?
RTrider
Posted: 11/23/11 10:31am Link  |  Print  |  Notify Moderator
OK, I think we are all set.
We found the reference in the chasis manual for tracing all engine (and other) parameters and found zero active engine faults, so we are going to go.
FYI, the flow charts are not labeled in the manual as such, but once found, they are very helpful.
Thanks for all those who replied.
wny_pat
Western NYS
Posted: 11/23/11 10:58am Link  |  Print  |  Notify Moderator
You might want to check that out.
Check with motorhome on level surface.
Transmission Fluid Hot.
Transmission in neutral.
Engine speed at idle.
diggermik
Illinois
Posted: 11/23/11 07:23pm Link  |  Print  |  Notify Moderator
Hi i had a similar problem on my Monaco.It finally ended up being the battery terminal connections on the house batteries. I know it sounds funny but that fixed the problem. worth a try
2009 Monaco Cayman 37 PBQ
