RV.Net Open Roads Forum: Class A Motorhomes: Help! my fiberglass looks awful.
 > Help! my fiberglass looks awful.
darbyjudy
New Port Richey
Posted: 12/04/11 04:55am Link  |  Print  |  Notify Moderator
I will also say use Red Max, it made my motor home look like new again. It has been on for about 8 months and it still looks good. Very easy to use.
2004 Gulf Stream 36 ft Sun Voyager triple slide
Workhorse W22 8.1
2004 Saturn VUE w/stowmaster towbar
Two Ole Pharts & One Little CocaPoo named Cuddles
ferndaleflyer
everywhere
Posted: 12/04/11 07:25am Link  |  Print  |  Notify Moderator
I did my 38ft DP with Red Max----last April. It took 4 or 5 coats but that thing looks new. I will give it another coat in the spring. Awhile back it was posted on here that Red Max was no longer available at Lowes---any truth to that?????
peaches&cream
Northwest Georgia
Posted: 12/04/11 08:07am Link  |  Print  |  Notify Moderator
I used Poliglow on a 1995 Holiday Rambler that was very bad looking. When I sold it 1 yr. later it still looked great. I like the prep solution that comes with Poliglow. It really cleans the fiberglass before application. That will determine how your MH looks using either process. Anything left on the MH before you start applying the sealer will show through. It is a time consuming (took about 12 hrs. to apply the sealer) on a 36 ft. MH. That is in addition to the prep time. 1 time a year will make your MH look great.
2005 Holiday Rambler Ambassdor, 36PRT, 330 Cummings
Toad 1995 Miata
wildtoad
Blythewood, SC
Posted: 12/04/11 08:21am Link  |  Print  |  Notify Moderator
Clean it, bleach it , scrub it with something like Bar Keeps Friend to get rid of any and all dirt, mold, black streaks, et al. Get you some Red Max Pro or as I did just good old Mop-N-Glo and wipe on 4 - 5 coats and you will be amazed at how good your unit will look. It really easy to do as cmpared to waxing.
Tom Wilds
Blythewood, SC
2000 Hurricane 30Q
hershey
Albuquerque,(fulltime) NM, USA
Posted: 12/04/11 08:56am Link  |  Print  |  Notify Moderator
Ask that question at 5 different Lowes and get 5 different answers.
My experience is:
Purchased a gallon with 4 or 5 gallons on their shelf last May. I gave the remainder of the gallon away to a fellow RVer.
It became apparent that it became scarce so I started looking for another gallon. Every Lowes I searched no longer had the gallon size in stock but now carry it in a 5 gallon size.
I finally found the last gallon on the shelve in the last Lowes I searched in Albuquerque.
Zep is the actual manufacturer of it and I understand that you can buy it under the Zep lable at Home Depot in gallon sizes.
hershey - albuquerque, nm
Someday Finally Got Here
Superman was an illegal alien.
NASCAR 14 - 99
Alpenliter
Fulltimer: Wherever we are!
Posted: 12/04/11 09:31am Link  |  Print  |  Notify Moderator
I heard they are reintroducing it back at Lowe's so I've been checking around down here in Arizona and have found it every Lowes I go to..
My first Wife Linda, 45+years
2004 F-450 CC, DRW 6.0 Classy Chassis Upgrade
Bulletproof Diesel upgrades
1997 33' Alpenlite
400 Watts Solar
Lifetime Good Sam Member #39644174
Escapees SKP#89882
Vietnam Vet '67-'68
Extreme Makeover RV Style!
chihuahuas
Irwin PA
Posted: 12/08/11 09:02am Link  |  Print  |  Notify Moderator
After winter I clean the motorhome with soft scrub, using a car brush. It will take all the black streaks off better than anything else I tried. After that I apply a good auto wax that you mix in water and again I use the auto brush which makes it easier than applying it by hand.
hershey
Posted: 12/04/11 02:05pm Link  |  Print  |  Notify Moderator
My experience is:
Why not purchase 5 gal? Does it spoil after storing awhile?
Because you only need perhaps a bit over a quart for a 36' MH. If you don't mind storing a 5 gallon container for years and years and years I guess it would be a good deal.
ferndaleflyer
everywhere
Posted: 12/04/11 07:09pm Link  |  Print  |  Notify Moderator
I bought 2 gal in the first place and the 4 or 5 coats I put on just about used up 1 gallon so I have a full gallon left---1 coat every spring should last 5 years or so.
peaches&cream
Northwest Georgia
Posted: 12/04/11 12:01pm Link  |  Print  |  Notify Moderator
My experience is:
