louholcombe
Decatur, Alabama
I have a 2011 Buick Enclave. While towing with 4 wheels down the milage runs up on the odometer. I have installed a charging line from the motor home to the battery on the vehicle so the battery will not run down. Does any one have any thoughts on this.
jrlibbie09
Colleyville
I think there is a fuse you have to pull.
Coachmen Encounter 37FW 2012
HSIKES
Wilmington,NC
crah wrote: louholcombe wrote: I have a 2011 Buick Enclave. While towing with 4 wheels down the milage runs up on the odometer. I have installed a charging line from the motor home to the battery on the vehicle so the battery will not run down. Does any one have any thoughts on this.
You need to follow your manual an pull the 50 amp fuse. I bought a taller fuse from autozone as the original fuse is difficult to remove. Pm me if you have questions.
X 2
Horace & Bobbi
DRAKE - Yellow Lab (rescue dog)
2005 Fleetwood Providence 39 L; 4 slides; 350 Cat
2000 Saturn LW TOAD
2009 Buick Enclave CLX 2
Preach the gospel at all times. And if necessary.....use words.
crah
Las Vegas
2003 Holiday Rambler Scepter 36PST 3 Slide
Cummins ISC 350/Side Radiator
Banks System
2011 Buick Enclave Towed
Ready Brute/Ready Brake/Blue Ox
1SG
Cloverdale, OR
We tow a 2010 Enclave. I pull the 50amp fuse, as stated in the owners manual, and the mileage does not accumulate on the odometer.
Paul & Sandy
2000 Winnebago Ultimate Advantage 36C
'56 Ford Customline Victoria
'62 Chevy Impala SS 409/4spd
U.S. Army Retired
Cloverdale, OR
mowermech
Billings, MT
Are you following the instructions in the Owners Manual?
CM1, USN (RET)
Toad: 2006 Jeep Rubicon LJ
over the hill
Tyler,Texas
Suggest that you go to your GM dealer and get the newly issued supplement on Dinghy Towing. It has been updated for the 2008-2012 Buick Enclave as well as other GM vehicles. You now have to pull two fuses in the specified order.
1- remove the 15 amp ECM fuse
2- remove the Batt 1 fuse
When reinstalling fuses, use the following order.
Install Batt 1 fuse first
Install 15 amp ECM fuse.
In the 2012 model year only, you have to remove three fuses.
But like I stated it's best to get bthe update from your GM Dealer
#07-00-89-021J: Supplemental Information.
