Francesca Knowles
Port Hadlock, Washington
mikestock wrote: RV daytrader wrote: buy the harbor freight 1000w for 110 bucks and dont worry about it!
That won't even run my converter/charger. It pulls 1000 watts for 15 minutes after the batteries have been only slightly discharged.
I thought I had something, but after reading the replies I don't know.
Most of the time there will be lots of other campers around so during the night would be my time of greatest concern. With game tickets going for $1500+ I'm sure there will be people staying at the RV during the game when we are gone. I have relied on a cable through the handle with a lock in the past but that wasn't New Orleans. I guess I'll just get the lay of the land when we arrive and decide the best plan. I carry two of these Hondas in my tool box. I may just leave this one in the box and move the other one in and out of the box. I just get tired of moving it.
One thing that occurs to me:
Won't your rig go three days on propane and battery power for heat, refrigeration, lights etc?
Unless it's all electric you might consider just doing that, maybe using the generator to recharge the batteries if needed and then locking it away again.
" Not every mind that wanders is lost. " With apologies to J.R.R. Tolkien
blangen
South Dakota... and everywhere.
Sorry... my one of these trumps your one of those.
B.O. Plenty
Minnesota
Putting a chain around the handle just means they can saw through the soft plastic handle with a hand saw. A bolt cutters works good as does a cordless grinder with a cut-off wheel. Any of these will result in a fast and easy removal in 60 seconds. There are no padlocks that are safe anymore. Best solution is to use it when you are there and put it away when you're not there...Or you could paint it yellow and write "Champion" on the side..
B.O.
2011 Big Country 3250TS...2010 Ram CC Laramie 4wd Cummins
15k Super Glide, Firestone Ride Rite, TrailAir Tri-Glide
Michelin XPS Ribs. Just say no to Chinese tires.
Twin Cities Mn.
mikestock
Vestavia Hills, AL, USA
There will be lots of entertaining and tv watching. I have four T-105's but I don't think they will stand up for 3 days and nights.
I've seen those steel caps for the handle but I think that any serious thief will come with a way to cut the cable.
Most anything I can do will only stop the opportunist thief. That's the guy that will grab it if it looks easy.
2005 F250 Crew Cab LWB Power Stroke, 2007 Montana 3500RL Fifth Wheel,Honda EU3000IS, Twin Honda EU2000i's, S&W security system
blangen
Ok... granted... maybe jobsite fluorescent green spray paint stripes is just a little too ugly for you. How about just writing your phone number in large numbers several times with a nice, fat permanent Sharpie. You can't stop the thief who wants it but you can make him not want it.
korbe
Northern California
And stick a dummy sewer hose down the hole, and put it over by your rig's sewer outlet.
2004 F250 SD PSD
2004 Crossroads Cruiser CF25RS
blangen
Hahahaha.... I'd be afraid of a 53 decibel porta-potty!
Ya know... you could combine two ideas. Get one of the cheapie generators that are not nearly as quite and cover it with the porta-potta after spray foaming the inside for sound proofing. The previously mentioned "dummy sewer hose" can be used as the exhaust!
jetboater454
Camping or home
Don't worry about it,they will probably steal your power cord anyhow.
"If momma not happy ....Who cares.I have my TH AND my toys .
2007 Gulfstream Endura Max 40
2001 Polaris Ranger 4X4
Mod Pics
we3
Birnamwood Wi.
All are good ideas but no one is thinking like a thief. First off what is to stop a person from putting a cinder block under your axel and sticking a knife through the sidewall on your tire? Your honda is gone in the time it takes your tire to go flat.
Also what is all of this talk of cordless grinders, you have a running powerhouse 6" away.
What I do is wrap a cable around it through the handle and padlock it to the camper. Recharge the batteries while I am there and put the honda away when I am gone
Sloop Smitten
San Marcos, CA
Put an alarm on it!
Six Sensor Wireless Home Alarm
1992 Fleetwood Jamboree Rallye 24' M/H
Ford E350 Chassis, 7.5L Engine, E40D Transmission
My other motorhome is a 1978 Catalina 25 Sailboat
Cruising Califonia, Sailing the Pacific!
