RV.Net Open Roads Forum: my new to me1984 23' winnebago chieftain
Open Roads Forum  >  Class A Motorhomes  >  Restoration & Vintage RVs
 > my new to me1984 23' winnebago chieftain
Page of 5
gusbratz
PA
Posted: 04/23/12 09:22pm Link  |  Quote  |  Print  |  Notify Moderator
some pics i found on the web may help, these are not of my stuff. mine is not this nice lol.
looking at the rear driver side of the top of the manifold. to the left of the screwdriver is the big 6 pin glow plug controller to the right is the oil pressure switch. correct me if i'm wrong.
front driver side head, temp sending unit? correct me if i''m wrong.
i have found the glow plug inhibit switch on top of the engine on the passenger side rear by following the wires. but on the outside rear of the passenger side head is this mystery switch. anybody know what it is?
gusbratz
PA
Posted: 04/24/12 09:08pm Link  |  Quote  |  Print  |  Notify Moderator
No takers? Ok here's a dumb one I can't figure out. What is this knob beside the key for? I broke the back of it apart accidently taking the dash apart.
Mr.Mark
California/Tennessee
Posted: 04/25/12 08:00am Link  |  Quote  |  Print  |  Notify Moderator
Gusbratz, would the switch be the dimmer for the dash lights?
MM.
Mr.Mark
2008 Monaco Dynasty, 42.2 ft., 4 slides, 425 hp clean-air Cummins diesel
2013 Honda CR-V EXL, AWD, w/Nav, SMI Air Force One vacuum-assisted braking
gusbratz
PA
Posted: 04/25/12 08:42pm Link  |  Quote  |  Print  |  Notify Moderator
i dont think so because the regular head light switch turns and has a detent i can feel. the head lights are not working right now though so maybe it has something to do with it.
Mike Hohnstein
Germantown, Wi
Posted: 04/26/12 07:47am Link  |  Quote  |  Print  |  Notify Moderator
you might want to spend some time here
I found the hard way that the 6v glow plugs with wide spades burn out real quick, changed to 12v haven't had problems with the momentary switch controlling the GP relay, count to 6 fire up.
hossman1210
riverside
Posted: 04/29/12 09:45pm Link  |  Quote  |  Print  |  Notify Moderator
the small knob on the dash is the intermittent wiper control.
gusbratz
PA
Posted: 06/20/12 02:26pm Link  |  Quote  |  Print  |  Notify Moderator
Finally getting around to making some more progress, got the engine running nice and all up to my standards. Brakes still need fixed but I decided to start working on the inside for a bit. I got all the carpet up and removed some of the dinette to get it out of my way while I do flooring. I am going to replace the front part around the doghouse with carpet; I saved the old pieces to use as patterns. We were planning on doing the rest with laminate but now that the rug is gone I can see the floor is buckled and warped from getting wet. The plywood in the bedroom is uneven with the rest of the floor and there is no way laminate will go over these bubbles. there is also a big hump in the floor right between the wheel wells. there is a 2x2 support under the floor there and it seems to be pushing up into the plywood but when viewed from under the coach all you see is the aluminum caladding on the bottom of the plywood and everythingl looks good. hmmmmm any ideas? Water seems to be getting in the back somehow as I can see the lower back wall is damp now that the bed is out. I may have to spend some time on the roof before I proceed with the building of bunk beds and framing in the old fridge opening for a dorm fridge and microwave. I hate the heat but the tar they smeared on the seams should come off easier in the hot sun so I can put the eternabond on.
what is this hose with nothing hooked up to it? is that where you suck antifreeze in to winterize?
big gap, like the plywood has expanded
gusbratz
PA
Posted: 06/21/12 12:42pm Link  |  Quote  |  Print  |  Notify Moderator
removeing tar to put eternabond down. removeing roof rack to remove tar. the tar is thick. can i put the roof rack back down overtop of the eternabond and shoot screws through it? will aluminum gutter sealent work as a caulking under screw holes and penetrations?
07blacktruck
BAF Afghanistan
Posted: 06/30/12 08:44pm Link  |  Quote  |  Print  |  Notify Moderator
Great post. It looks like you are making good progress on bringing it back. I love to see that. Keep us posted on what you are doing with it. I recently got an 89 Winnebago. Mine didn't need too much but I plan to keep it and am really interested in what you are doing and running into. Keep up the posts.
Stay safe out there.
Ken
The inherent vice of capitalism is the unequal sharing of blessings;
the inherent virtue of socialism is the equal sharing of miseries. Winston Churchill
bsinmich
Holland, MI
Posted: 07/01/12 05:53am Link  |  Quote  |  Print  |  Notify Moderator
If the 6" wide Etarnabond would cover the edges of the tar you might not have to do all of the removal. As long as you can get 1/2" grip on each side of the Eternabond it will hold. I would use Dicor self leveling caulk for the screw holes you want to put through the tape.
2003 Newmar Mountain Aire, Workhorse W22, 2008 Saturn Vue, Falcon 5250, & US Gear Unified Tow Brake
Page of 5
