RV.Net Open Roads Forum: Class A Motorhomes: "Tall" Class A
 > "Tall" Class A
Hatman
Columbus, OH
Posted: 01/05/12 01:29pm Link  |  Quote  |  Print  |  Notify Moderator
I've been looking at older (2000-2004) Class A DPs and wondering if certain makes/models have a taller interior ceiling height? At 6'4" tall, that's an important feature. Even looking at the manufacturer's literature for these older models isn't entirely helpful, as they often don't list that spec. Naturally, I can and will check out as many as possible, but it would be good to know if there are certain makes/models that I can scratch off my list.
Thanks!
bluwtr49
Green Valley, AZ
Posted: 01/05/12 01:55pm Link  |  Quote  |  Print  |  Notify Moderator
I was chatting with a couple in a similar situation and he found that an Alfa had suitably tall ceilings.
Dick
2000 40" DP Beaver Patriot Thunder Cat C-12 425 HP, 1550 Tq
1997 Jeep GC Limited ---toad
2008 Toyota Tundra Crew Max Limited TRD (Retired)
2009 Cougar 268 RLS ~8700 lbs road wt (Retrired)
2006 Jeep Liberty Turbo Diesel.....TV in Training
rv2go
Fulltime (Knoxville, TN).... or someplace else
Posted: 01/05/12 01:58pm Link  |  Quote  |  Print  |  Notify Moderator
The Alfa has about the highest ceiling that I know of. In fact short people have to use a step to reach some of the overhead cabinets.
Winnebago Journey
TN Lic. RV 2 GO
Jeep Cherokee 4x4
www.rv2go.us
I'm here #4335
Travel Photos
gfs1943
Whitney, Texas
Posted: 01/05/12 02:18pm Link  |  Quote  |  Print  |  Notify Moderator
Itasca Horizon/Winnebago Journey list interior height as 6' - 8". I haven't measured it, but it's way over my head!
gfs1943
USAF, Retired (1962 - 1983)
'00 Itasca Horizon 36LD
Cat Diesel Power
2006 Honda CR-V
janstey58
Glenwood, IA
Posted: 01/05/12 02:22pm Link  |  Quote  |  Print  |  Notify Moderator
My 09 Bounder has nearly 7ft ceilings.
Jeff and Kim
2009 Bounder 35H (Gas Workhorse chassis)
2012 Ford Escape Limited Toad
daveshan
Durango Colrado
Posted: 01/05/12 02:39pm Link  |  Quote  |  Print  |  Notify Moderator
The older Alpines have 6'7" height. The Beaver (04 Patriot Thunder) that a friend has is at least as high.
'99 Alpine 36SDS/8.3 ISC 330 Cummins
Or
'05 Lance 845
'06 Super duty SC/SB 6.0
Upgrades include: StabilLoads, Air Bags & Timbrens,Swaybars
Usually towing an '01 Wrangler, lifted/locked on 35"s or a mildly built '98 Cherokee on 33"s (only one locker)
bgholson
New Waverly, Tx
Posted: 01/05/12 02:42pm Link  |  Quote  |  Print  |  Notify Moderator
When buying my 03 HR I was told in 06 the ceilings were higher. I'm also 6'4 but moved up from a TT so had already adapted to low ceilings
2003 HR Imperial 40 PKDD
Daveinet
il
Posted: 01/05/12 04:16pm Link  |  Quote  |  Print  |  Notify Moderator
Do a search here on Alfa before you buy. There are some serious delamination issues with some years. Not sure if it applies to all Alfa's or just some.
Dave
The Flying Fortress
FMCA F298817
'83 Revcon Prince 31' FWD
502 w/Howell/GM 16197427 ECM/Edelbrock MPFI,Thorley's & Magnaflows,
4L85E 4 speed, KoniFSD,
6% grade = wanna drag?
MISC photos
Revconeers Forum
Ivylog
Blairsville, Ga. USA
Posted: 01/05/12 04:38pm Link  |  Quote  |  Print  |  Notify Moderator
At 6' 4" too, I've turned around and walked out of many a RV because of a low ceiling. The lowest point in my MH is 6' 6" at the sliding door between the front and back. The ceiling is 6' 7 1/2" and around 06-07 Monaco added another 4" to the higher end DPs. I would stay away from Alfa's as they had lots of problems.
04 Monaco Dynasty 42' quad slide
Where am I?
How I tow.
doc brown
Redondo Beach, CA,
Posted: 01/05/12 04:43pm Link  |  Quote  |  Print  |  Notify Moderator
I'm 6'5" and own a 2004 Country Coach Inspire with a 7' ceiling. In 2004 only 2 manufacturers had 7' ceilings, Alpha and Country Coach. Since then 7' has become the ceiling standard.
Steve,Kathy,Josh & Morpheus the Basenji
2004 40' TSDP Country Coach Inspire DaVinci
350 Cummins, 3000 Allison
2008 Wrangler X Rubicon/Blue OX Tow Bar/Ready Brake
 > "Tall" Class A
