RV.Net Open Roads Forum: Technology Corner: Sat Dish to use in 5th Wheel
 > Sat Dish to use in 5th Wheel
JEBar
Willow Springs, NC
Posted: 01/06/12 07:07pm Link  |  Print  |  Notify Moderator
years ago we had a roof mounted dome dish made by Winegard installed on our 5er .... while it works well, looking back I wish I'd saved the money .... if there is one tree in the CG, there is no doubt it will be located between our camper and a clear view of the southern sky ... as a result we also carry a portable antenna ... over the years we've tried several and for us the VuQube 1000 has proven to be the best we have found .... I'm not a fan of tripod dish mounts but have found that using a Winegard Carryout Tripod Mount to be very dependable .... using it gets our VuQube off the ground and when properly tied down it has ridden out some very strong winds .... we've had both Dish and Direct, both will deliver a signal .... of the two we have settled on Direct, for us it is simpler and has excellent national coverage
Jim
* This post was edited 01/06/12 07:15pm by JEBar *
'07 Freightliner Sportchassis
'06 SunnyBrook 34BWKS
Kenc_AL
Wedowee AL
Posted: 01/06/12 08:49pm Link  |  Print  |  Notify Moderator
For manual set up:
If you are ok with SD, go Direct. Easier set up than Dish SD.
If you want HD, go DISH. Easier set up and more channels than Direct HD.
I currently have Dish HD and have a portable homemade support made from PVC which to me is easier to set-up than a tri pod. Takes me about 10 minutes.
sirdrakejr
Las Vegas, Nevada
Posted: 01/06/12 10:29pm Link  |  Print  |  Notify Moderator
Moved from 5th wheels to technology corner.
Frank
RossNSally4Montanas
On The Road
Posted: 01/07/12 08:56am Link  |  Print  |  Notify Moderator
Just want to apologize for upsetting some by posting twice on this subject. We are new at this and I'm sure will make many mistakes. Thanks to everyone who responded with advice.
rreynold51
United States
Posted: 01/08/12 05:15am Link  |  Print  |  Notify Moderator
We like our VuCube also...we tried the tripod type for a while...but a lot easier to throw the cube on the roof, so there's no trees in the way, then go sit in my chair and tune in the sat.....much nicer from the comfort of the easy chair...of course auto tune would be even better!!
Rick & Debbi NJ5W/N5GHN
El Paso, Texas
jmiller
S.E. Michigan
Posted: 01/08/12 05:55am Link  |  Print  |  Notify Moderator
Dish network and the Tailgater. Automatic and easy to setup.. My 2 cents..
Joel, Sallie and our lab Jager.(father and son) Chance 9/8/12 RIP
2009 Ford F150 4x4 XLT scab 5.6' Tow Command (NEW 4/09)
2007 Trail Bay TB27RL(NEW 7/09)
Hensley Arrow/Barker VIP 3500/Steadyfast/Dish Tailgater/Maxxis tires/Honda EU2000i
firedguy
Sun City West, AZ
Posted: 01/08/12 02:57pm Link  |  Print  |  Notify Moderator
We just saw a new Tailgater in the RV dealer parts store. Looks exactly like a VuCube. It claims to get Direct TV HD? I was under the impression that the Winegard Auto Carryout was the only carryout that got HD and only on Dish Network.
Any experience with this unit?
2011 Chevy Silverado 3500 1LT trim, DRW, Duramax/Allison 6spd.
2011 Jayco Pinnacle 4slides, 40ft, 15000lbs GVWR.
jmiller
S.E. Michigan
Posted: 01/08/12 03:56pm Link  |  Print  |  Notify Moderator
The tailgater is only used for the dish network.. Yes it is very easy and fast to setup.. You can find the tailgater for $350 or so on line.. This is the way to go in my opinion....
* This post was edited 01/08/12 06:36pm by jmiller *
gmg
Houston, TX, USA
Posted: 01/11/12 09:34pm Link  |  Print  |  Notify Moderator
We have the Wingard automatic. It works fine with Dish Network. We are receiving three Satellites for our programing. We have only used it in Texas so I don't know how it works in Idaho but I suspect it will be fine. All it requires is a view of the Southern sky. If you have an I-phone, there is a wonderful little application that lets you easily find the sattelites. I use it to make sure there are no obstructions between the dish and the satellites. From then on the automatic dish automatically rotates and elevates until it locks onto the 3 birds. When you change channels it sometime has to move slightly to peak onto the propert satellite but that is done automatically. So far we like ours.
GG, 03 Silverado 2500 Crew Cab DA; Pullrite Superglide Hitch; 05 Everest 294L 5th Wheel.
cpaulsen
California
Posted: 01/13/12 03:26am Link  |  Print  |  Notify Moderator
I use Dish HD on a tripod. Takes about 5 minutes or less to set up. Over Christmas...way too many trees around so I set the Dish up away from the 5ver and had it dialed in about 2 minutes.
cpaulsen
