old grand dad
Colorado
2001 beaver class a diesel on magnum chassis. no turn signal or hazard lights. suspect defective turn signl-hazard flasher. anyone know where it is located? other suggestions for the problem?
concord32
Indianapolis
Look on or near the fuse panel under the dash. Should be located on or near there.
2011 Coachmen Concord 32' Triton V-10 1-slide.
pulsar
Lewisville, NC
Moved from Forum Technical Support.
RV Jim
Palmyra, Pa.
You normally have TWO flashers, one for each
Check fuses first
dougrainer
Carrolton, Texas
As previous post, the hazard and turn signals are on seperate fuses and relays. Odds are, since BOTH are inop, check the quick connect on the steering column. There will be a top cover around the turn signal lever and below that is the harness quick connect for the turn/hazards. Sometimes, you can move the adjustable tilt column up and down with the hazards or turn signals on and if it is that quick connect, you will get a momentary operation of the lights and that tells you it is the quick connect. Doug
Shot-N-Az
Va
Also check the connections at the bulbs. I discovered a corrosion problem on mine recently.
exeter_acres
North of Atlanta, GA
burnt out bulb?
old grand dad
Colorado
i cannot locate the fuse panel. boy have i tried!!! where might it be? doug, thanks for the suggestion. i will try the steering column quick connect.
dougrainer
Carrolton, Texas
Shot-N-Az wrote: Also check the connections at the bulbs. I discovered a corrosion problem on mine recently.
But that would not keep the dash cluster from coming ON. Doug
Ames
South Central Florida
Beaver Ambassador Club is the Beaver Owners Club. You can browse the forum without being a member but consider joining it is a valuable source of information and if you think you would like to go to rallies with fellow Beaver Owners a good bunch of people who love to have fun.
Richard and Babs and a Bob Tail Cat
97 Beaver Patriot 40 Kitchen Slide
330 HP Member FMCA, BAC, Good Sam, CAT RV Club
Toad 2012 Dodge Durango RT AWD Hemi
