RV.Net Open Roads Forum: Tiffin Entry Steps Safety issue the reason?
 > Tiffin Entry Steps Safety issue the reason?
donscomp
Camarillo,CA
Posted: 01/19/12 08:57am Link  |  Print  |  Notify Moderator
We have/had a Tiffin RED and trading it in for a Phaeton. I guess this is because of a safety issue but.....
It use to be on coaches(Monacos)we have owned before, that we would pull in front of the house, have the step switch on, open the door real quick and close it, turn the entry switch off, wait a sec and open the door. The steps would stay IN. The reason to do this is because of the curb.
Now in the RED and all Tiffins I think now. You can NOT have the steps remain in. Parked I mean. Of corse they will come and stay in at key turn on.
I did hear of someone using a small magnet to fool the steps into thinking the door screen door is shut.
Anyone else have any ideas or familier with this problem?
Thanks all.
Don
**2011 Tiffin Phaeton 36QSH**
** Wish we were Fulltime **
** Friends Of Bill W. **
**GIT-R-DONE!!**
BobGed
Carson City, NV
Posted: 01/19/12 10:31am Link  |  Print  |  Notify Moderator
The magnet solution works for me.
2009 Tiffin Phaeton 40QSH
2011 Jeep Wrangler Sahara
dougrainer
Carrolton, Texas
Posted: 01/19/12 11:02am Link  |  Print  |  Notify Moderator
Your Monaco was wired just like the Tiffin. ALL steps IF wires to specs will do as you have the problem with. It is called LAST OUT. That is to keep someone from falling on their BUTT when they open the door regardless of the position of the wall switch or key switch. EVEN with the KEY ON, the steps will extend because of the override system. The BEST way to stop the steps from extending when next to a curb is to run an inside switch from the POWER supply wire at the step and that kills the power to the step to keep from extending. Doug
Greyghost
On The Road To Somewhere
Posted: 01/19/12 12:57pm Link  |  Print  |  Notify Moderator
That sounds like a real convoluted system and safety issue. My older Winnebago and my current Newmar have a power switch for the steps that will allow me the option of having the steps open or stay closed when the door is opened. Are you sure there isn't something similar on your coach. Having said that both of my coaches were/are gassers.
Pat & Roger Fisher
2004 Mountain Aire 3501
2007 Honda CRV EX-L 4WD,
Jewel and Clifford Bouvier Des Flandres
PackerBacker
Montreal (Qc) Adirondacks (NY) Myrtle Beach (SC)
Posted: 01/19/12 01:30pm Link  |  Print  |  Notify Moderator
I have a similar issue with the sidewalk when I park in front of the house. There's seems to be one exact spot in the street along the curb that if I hit it right, the steps will clear the sidewalk. I got fed up going forward and backing up to find the street's sweet spot so now I just pull up, put the jacks down and raise the right side a little.
Eric
2009 Holiday Rambler Admiral 33SFS (34' 3")
2008 Jeep Liberty - North Edition (4x4 auto)
FQCC/Camping Quebec, KOA, Good Sam, Coach-Net
wny_pat
Western NYS
Posted: 01/19/12 01:45pm Link  |  Print  |  Notify Moderator
My old '94 Tiffin had a oem override switch right by the entry. You could switch to lock it in, or lock it out, or open and close with door. Guess they did away with that?
I remember some discussion concerning this topic over at www.tiffinrvnetwork.com along with some modifications you could do to make it work the way I described above. One would think that the step manufacturers would build in a safety device that would return the step to the closed position if it hits anything (like a garage door), along with a flashing red light to warn the person exiting the coach. But we all know about added cost factors and the bean counters.
fourmat
NJ
Posted: 01/19/12 01:50pm Link  |  Print  |  Notify Moderator
I have not seen any in the last 5 years that dont operate the same way as the Tiffin. dougrainer is exactly correct it is last man out
2009 Challenger
okgc
Southern Michigan
Posted: 01/19/12 01:54pm Link  |  Print  |  Notify Moderator
Yes this is considered a safety feature by the manufacture Kwikee. The steps also should stop going down when they hit something like a curb.
2010 Tiffin Allegro RED 36 QSA with Chevy HHR toad
2009 Chevy 2500HD CC 4x4 w/6.0 Vortec
Sundowner horse trailer
My hobby cars
1965 Chevy Impala SS 396
1964 Chevy Nova SS
donscomp
Camarillo,CA
Posted: 01/19/12 02:35pm Link  |  Print  |  Notify Moderator
Thanks all for the replies.
Our last Monaco was an 06 Dip and it was the same as all the rest. Could leave it in.
Then we went 5ver and well. Then the RED and thats when we noticed.
Bob. Small magnet? What did you do if you dont mind?
dougrainer
Carrolton, Texas
Posted: 01/19/12 02:53pm Link  |  Print  |  Notify Moderator
Your systems were not wired correctly. Yes, I work for a Newmar dealer. ALL, if wired correctly, will have the LAST OUT regardless of the wall switch. The ONLY exceptions are steps that are powered by the COACH batteries and subject to the coach battery disconnect. IF the door is closed and you turn off the coach battery disconnect, since there is NO power to the step, it will stay wherever it is. Doug
