indyzmike wrote: SAFETY NOTE: While towing, hand check the temperature of wheel hubs at every stop. I always do a walk-around to check tires, hubs, lugnuts, and hitch.
You got it out before me.I do that very same thing when traveling, I use the back of my hand to feel for heat..
A new toy I bought since this incident is an infrared temp reader. Less than $30 and I know the temp of the bearings, tires, the guy driving beside me, oil pan, roasted marshmello, a tree...............fun at parties to
Liverchip wrote: As far as the back-of-the-hand check or thermometer check goes, how hot is too hot? My old Jayco with the 12 inch wheels got pretty toasty at times.
With my gun on it 37-39C\100F measured at 25C\77F ambient. If you can't hold onto it with your hand it's too hot!!!! It will also depend on the outside ambient temp. Again though if you can't hold your hand on it it's time to check it now!
If a bearing is failing that hub will be much hotter to the touch than the others.
2007 Jayco 23B
2009 E350 Ford Club Wagon 5.4 w/ tow pkg
Equalizer hitch, Prodigy P3 brake controller
Buddy 125 Scooter-FUN!
1997 Coleman Sunridge- Served us well for 11 years!
