captbru
Crystal River FL
Having alot of things breaking and now have about 4000K in repairs on a seven year old truck. Upper oil pan leaking, power mirror broken, A/C mode in dash not working, suspension problem and now the speed gage jumping around. What do you think fix it or go out and spend alot of money for a new truck????
Truck other than that is in very good condition.
2011 Keystone Laredo Fifth Wheel 310RE
2012 GMC 3500HD Dually 4x4 Duramax/Allision
Engineer9860
Eagle Scout dad
Google the dash issue. There are some independent shops that fix them on the cheap. Some even have exchange programs so your truck is not down for an extended period of time.
What is your suspension issue?
In Memoriam: Liberty Belle
jalichty
Lander, Wyoming 82520
I had a 2003, bought in 2002, GMC Duramax Diesel and was putting money in it as well as having one particular thing, the PRNDL(Park/Reverse/Neutral/Drive/Low) switch had to be replaced, after warranty was out, three times. Paid for the first one but the other three were no cost other than the time to take it into the dealer and wait for them to get it "fixed". Last summer we spent about $1,500 in out-of-warranty repairs and decided we had had enough. Looked around and the best price by about $8,000 to $9,000 was a Dodge Ram 2500HD diesel with a six-speed manual, 3.42 rear end and long box. The GMC towed great and I really liked the truck but was getting tired of not knowing when it was going into the garage. Haven't towed the new fifth-wheel yet but perhaps in a couple of weeks will get to do so when picking up our boat at the dealer where our fifth-wheel is currently sitting. I would look for a new truck, but that's just me. I'm not a good mechanic, accountant by profession, so I don't like thing that are not covered by warranty generally.
John A. Lichty
donn0128
Pronounced Ore-gun
The dash gage issue is a known and very common problem. That can be fixed on an exchange basis for a couple hundred dollars if dealer(GM) is not willing to do it for free. Depending on where you are getting the quote for repairs it sounds quite high. I guess depending on miles I would consider taking that 4K and putting it toward a new truck if I were in your shoes. Maybe it's time to try a different brand.
Donn,Lorri,Max (The Rescued Lab)
Resident Know It All
jwb187
Southeast Missouri
If you trade for a new one it will cost you a fortune, I would try to find a year or two newer 2006-2007, any newer have the huge exhaust pipes that are required to burn off the captured soot from the newer diesel engines, and are much less economical and require more maintenance and costlier repairs....jmho
2008 Chevrolet Crewcab LTZ 4X4 duramax/allison
2008 Big Horn 3055RL 5'ver
Kipor 3500ti Genny
2005 Yamaha Rhino 660
60 gal aux tank/tool box combo
Turtle n Peeps
California
New trucks are about a grand a month in payments.......or more. So that means you will only be covered for about 4 months in payments for fixing your truck. The other 50 payments or so are on you then.
I know what I would do.
Sounds like you just want a new truck though. Nothing wrong with that.
outside the fire"
ronfisherman
SE Michigan
Lot of in for repair a Duramax truck on Diesel Place. If you can use a soldering iron the speedometer can be repaired for less than $25.
Kodiak Chassis Class C Forum
45Ricochet
North Idaho
captbru wrote: What do you think fix it or go out and spend alot of money for a new truck????
Would depend on how many miles it had. Sure sounds like it has lots of miles on it.
06 Ram 3500 CC LB Laramie 4x4 Dually 5.9 Cummins Smarty Jr 48RE Jacobs brake
GVWR 12,200 RAWR 9350
06 Grand Junction 34' High profile 15500 GVWR 3200 pin Mor/ryde 5500 Onan genny Dual A/C Wet bolts
27' Hallett 502, 500HP
captbru
Crystal River FL
Trucj has 142000 miles on it
