enblethen
Moses Lake, WA
The OP drove it home after purchase and parked it.
Something has failed abruptly such as blow fuse.
OP:
Did you do anything after parking that may effect it? Did you change oil and possibly hit the oil pressure sending unit?
Bud
USAF Retired
Suzuki XL7 pushing Pace Arrow
T bone
Amarillo
Probably been mentioned--turn on for three seconds then off-repeat-do this several times and see the results---this is to build fuel pressure..
1999 Georgetown 325S,V-10 Ford.
2002 Ford Ranger Edge toad
carrying a 2001 Yamaha Warrior.
PaulJ2
Northwest Oregon
Daveinet wrote: Quote: There is one more thing here, hence my question about the keypass security system. IF you have this system (security light on in instrument cluster)it needs to recognize the correct key and only that key to start/run. Many GM cars and trucks came with that system but I am not aware if MH's ever used it or not. VATS is in the software, but it is disabled in every truck BIN I have seen. The 7427 was a precursor to OBDII, so there are a bunch of features in the software in preparation for the later series ECMs that are not used in the '95 and older vehicles.
Thanks for the info. I still believe it is a fuel pump relay problem keeping it from starting. The 2 second blip should be enough to get it to fire, but if not, the ignition reference pulses from the distributor module should keep the relay energized while cranking the engine. Don't know if he has changed that relay yet.
DANDEAKINS
CHATTANOOGA
WOW__WOW__WOW__, Man what a site!!! Got me a fuel pressure tester today, The power fuse on the fuse bank showed good, no problems under the dash pod as for as fuses and circuits. Down in the teens tonite and tomorrow and old winnie is outside, I'm on hold right now. Thanks Gang and god bless.
supra24valve
Jackson, Ohio
Replace both and be done with it!http://www.autozone.com/autozone/parts/1........et-P30-Van/Fuel-Injector/_/N-jcr6lZ8vd08
RCtime
So. Calif.
DANDEAKINS wrote: WOW__WOW__WOW__, Man what a site!!! Got me a fuel pressure tester today, The power fuse on the fuse bank showed good, no problems under the dash pod as for as fuses and circuits. Down in the teens tonite and tomorrow and old winnie is outside, I'm on hold right now. Thanks Gang and god bless.
man thats mighty cold, and god bless to you, On hold is good.
Ron
2002 34HD Winnebago Journey DL, Cat. 330/freightliner
2004 Honda CRV - Garmin 1490t
Great wife & Cavalier King Charles Spaniel
TT/N
Daveinet
il
interesting that you expect both fuel injectors to fail at the same exact time.
Dave
The Flying Fortress
FMCA F298817
'83 Revcon Prince 31' FWD
502 w/Howell/GM 16197427 ECM/Edelbrock MPFI,Thorley's & Magnaflows,
4L85E 4 speed, KoniFSD,
6% grade = wanna drag?
MISC photos
Revconeers Forum
supra24valve
Jackson, Ohio
Daveinet wrote: interesting that you expect both fuel injectors to fail at the same exact time.
If power and ground was good at the injectors.but no power at cranking.you need to pull the four pin conector at the distributor .With light conected to oneof the injector harness and a test light hooked to 12 volts prob the purple and white wire I do believe ckt 436 when you probe it should light the noid light.So if this is the case then the ignition module is bad..also check power cranking at 5 amp fuse in fuse panel.
If fuel pump, and filter are all ok...than replace injectors, i have had the same thing happen on a truck, with no start and spray into the throat would start for a few seconds.
racer99
channahon
The fuel pump may be pumping when line is disconnected but fuel pump may not up to snuff as far as fuel pressure-Check fuel pressure- my nickel is on low fuel pressure -either bad pump or restricted fuel filter-Who knows how long the MH sat before it was driven to his house any rust or dirt or water probably got pumped into filter-As was stated earlier if fuel was sprayed into intake it would fire then die-Rich
enblethen
Moses Lake, WA
OP: Fuel pump relay is actually mounted to the left side wind deflector under the engine cover just above the valve cover toward the rear of engine.
You can check continuity on the injectors. I very much doubt whether they have both failed.
