RV.Net Open Roads Forum: Dinghy Towing: What brake controller would I need?
Search only in Dinghy Towing
 > What brake controller would I need?
MSHappyCampers
Columbus, MS
Posted: 02/11/12 09:05am Link  |  Print  |  Notify Moderator
I am looking at buying a Class A that has never towed a vehicle. We have a 2001 Honda Accord with GVWR of 4235 lbs. What is the most economical braking system I can use for that vehicle? We will be traveling in the mountains quite a bit. Is it advisable to tow a vehicle that size without supplemental braking? Your advice is appreciated! [emoticon]
Joe & Annette
2002 Monaco Windsor 40PBT
jauguston
Bellingham, WA
Posted: 02/11/12 09:09am Link  |  Print  |  Notify Moderator
delete
2005 Coachman Sportscoach Elite 402 40'
350hp Cat C-7 w/MP-8
7500w Onan quiet diesel generator
6-Kyocera 130w solar panels SB3024i MPPT controller
Pressure Pro TPMS
1987 Suzuki Samurai tintop Toad w/VW 1.6 turbo diesel power
jauguston
Bellingham, WA
Posted: 02/11/12 09:10am Link  |  Print  |  Notify Moderator
That's easy! Ready Brake. Simplest, easiest to hookup and unhook and easy install. No box to lift in and out of the vehicle. Also least expensive.
Jim
wd
SoCal
Posted: 02/11/12 09:18am Link  |  Print  |  Notify Moderator
Jim
X-2 on the Ready Brake. I've used Brake Buddy and US Gear.
last toad I installed Ready Brake, simple install and works great.
seatboard
South Carolina
Posted: 02/11/12 11:38am Link  |  Print  |  Notify Moderator
Check out Air Force one Braking System. It works off the towing vehicle's braking system. The small control box fits under the hood and does not take up much space. The important thing to me as old as I am, "THERE IS NO GETTING DOWN ON YOUR KNEES AND HOOKING IT UP TO YOUR BRAKE PEDAL EVERYTIME YOU HOOK UP THE DINGY." It is permanitaly installed.
Harold and Faye US Navy Retired
2006 Fleetwood Revolution 40LE
400 cat
mowermech
Billings, MT
Posted: 02/11/12 12:11pm Link  |  Print  |  Notify Moderator
Jim
That is absolutely the only system I would ever buy!
"Is it advisable to tow a vehicle that size without supplemental braking?"
That is a decision only you can make. Such systems are not required by law in many states. Where they ARE required by law, the law sometimes specifies that such systems must "be approved by the Administrator". Which ones have such approvals? Nobody seems to know! Perhaps because none of the normal testing organizations have ever, AFAIK, done any testing! Many thousands of vehicles were towed many millions of miles before these systems were ever invented, with minimal problems. There have been literally thousands of posts made in various RV forums about the issue. Search them out, read to your heart's content, then decide what is right for you.
Good luck.
* This post was edited 02/11/12 12:18pm by mowermech *
CM1, USN (RET)
Daily Driver: '06 PT Cruiser Turbo
Toy: 1999 Dodge QC SWB, Cummins, 5 speed, 4X4
Other toys: a pair of Kawasaki Brute Force 750 ATVs.
jauguston
Bellingham, WA
Posted: 02/11/12 01:00pm Link  |  Print  |  Notify Moderator
seaboard,
Same thing as Ready Brake. 30 second hook up and no bending over lifting anything(-:
seatboard
South Carolina
Posted: 02/11/12 03:47pm Link  |  Print  |  Notify Moderator
jauguston wrote:
seaboard,
I am not familiar with ready brake but if it is the same it is good for us old folks. Does the Ready brake hook into the RV air system?
MSHappyCampers
Columbus, MS
Posted: 02/11/12 09:51am Link  |  Print  |  Notify Moderator
Question on the ReadyBrake and others that press or pull the brake pedal. I've always thought that it was really hard to stop a vehicle without the engine running. What about this?
jauguston
Bellingham, WA
Posted: 02/11/12 09:56am Link  |  Print  |  Notify Moderator
It is not a issue. Federal law for many years has mandated that vehicle brakes must be able to safely stop the vehicle if the engine is stopped and the power brake unit is not operational.
© 2017 CWI, Inc. © 2017 Good Sam Enterprises, LLC. All Rights Reserved. | Terms of Use | PRIVACY POLICY | YOUR PRIVACY RIGHTS
