RV.Net Open Roads Forum: Fifth-Wheels: hauling my golf cart
 > hauling my golf cart
Page of 7
MPI_Mallard
McGregor Ontario,St. Cloud Florida
Posted: 02/11/12 08:32pm Link  |  Print  |  Notify Moderator
I'm looking for some advice about my golf cart and how to take it with me,i have 38' CC Daydreamer and a four seater precident golf cart,originally i was going to build a swivel wheel trailer but as triple towing in Georgia and Florida is illigal that's looking like a bad option so hows about hanging the cart off the rear of the fiver',i have a class III reciever hitch welded to the frame and i'm starting to think this is the way to go,i imagine a couple of arms off both ends of the hitch sticking out to support two pieces of steel channel the width of the tires.So waddya' all think!
07' Dodge 3500 6 speed Cummins Diesel Dually/6.7L Bully-Chipped /
Exhst Brake/07' Cedar Creek 37CDTSD Daydreamer fiver
Mallard @ Frau Blücher
Red Green:
Now lets Bow your heads for the men's prayer.
I am a man, but I can change.
If I have to, I guess...
DrBaker
Oklahoma
Posted: 02/11/12 08:42pm Link  |  Print  |  Notify Moderator
I would be concerned with the weight on the back of the 5er.
I thought the swivel wheel platform was not a double tow, but an extension of the 5er since there was no pivot point???
2011 Chevy 2500HD CC/SB 4x4 Victory Red
2003 Crossroads Cruiser CF27RL
Champion Screamer, Reese 16k, and a Blue Status Symbol
MPI_Mallard
Posted: 02/11/12 09:51pm Link  |  Print  |  Notify Moderator
Yeah,as far as the weight is concerned a couple of my rv buddies are of the opininion that my fiver is so heavy it won't make a difference and after talking to the Florida DOT their position is if it has wheels and lights it's a trailer so thats that,as a visiting Canadian i'm not willing to break the laws of a country that has shown me and Frau Blücher so much hospitality,this going to Florida for the winter is the way to go,all that's missing is my cart!!
byronlj
Arizona
Posted: 02/11/12 11:15pm Link  |  Print  |  Notify Moderator
I doubt that your 5'er frame could support that much weight bouncing up and down without damaging it.
Dave
byronlj
07.5 Silverado LTZ Ex. Cab 3500HD dually 4X4 duramax LMM/allison 6spd
07 HR Presidential Suite 37RLQ
dan-nickie
Grand Prairie, TX
Posted: 02/12/12 05:23am Link  |  Print  |  Notify Moderator
I think you are outta luck without being able to double tow.
Dan and Nickie, Four Winds 31p, Retired Jan/2011
lambchop
WI
Posted: 02/12/12 05:54am Link  |  Print  |  Notify Moderator
Maybe a Toy Hauler?
2008 38.5 ft. 3500RLQ 4 Slide Montana 5th wheel
2001 One Ton Chevrolet Truck Dually 8.1L Allison 4:10
US Air Force Vet 1958 - 1965 Cuban Missile Conflict 1962
LakeEffect
Michigan
Posted: 02/12/12 06:04am Link  |  Print  |  Notify Moderator
Did you consider renting a golf cart? We go down to the RGV and there are co's that deliver them to your site.
Just a thought.
Good luck
2011 Cougar 291 High Country
2011 Silverado 2500HD 6.0
2 Kayaks, 2 bikes, golf clubs and hiking shoes
Suzuki V Strom 650
Cody, Yellow Lab/Brittany mix
PatnRich
MA
Posted: 02/12/12 06:25am Link  |  Print  |  Notify Moderator
We're in FL and rented a cart this season for 3 months.
My wife hurt her knee and could not ride her bike to the activities. If you decide to go this route, you may want to call in advance and try to reserve a cart. When we tried to rent we had to make quite a few calls to find one.
2010 Montana 3400RL, 2011 Ford F350,CC,SB,16K Pullrite SuperGlide
tnance
Nixon/Texas
Posted: 02/12/12 07:43am Link  |  Print  |  Notify Moderator
I doubt your fifth wheel has the sufficient frame strength. I also would doubt your pickup has the capability to safety tow the combination.
My friend did exactly what you want to do. He hauled his golf cart on a basket that attached to his Teton fifth wheel using three receiver hitches. He did this successfully for several years.
His Teton fifth wheel, (24,000 GVWR), has a 14-inch I-beam frame. Teton frames run all the way to the rear bumper. Without the golf cart his pin weight ran near 6,000 lbs. With the golf cart his pin weight was down to 5,000 lbs. He used an MDT to tow the combination.
His only complaint of the setup was he had to be very careful in making turns. The golf cart basket would swing into other lanes when making turns.
2005 Freightliner M2 106 class 7 HDT
2004 Teton Sunrise Grand
Jeep Wrangler toad
...PICTURES...
AC09
Yuma
Posted: 02/12/12 08:05am Link  |  Print  |  Notify Moderator
On our last trip I saw a 5er with a platform on the back like you described. The guy had a Polaris Razor on it, I know those things are much heavier than a golf cart...I didn't get a chance to see how it was built because we where on the road and he was traveling the other direction. I believe it can be done though, depending on the rigidity of you 5r. I wouldnt go the TH route unless you are going to get one of the "garage models" especially since you are traveling from Canada and living in it all winter. TH are not built for comfort and you are already used to the amentities of your 5r.
Page of 7
