captbru
Crystal River FL
Never had a dually before and I have another tire pressure question. The tires are LT235/80R17E rated for 80PSI, the door post states the following. FRONT 70PSI, REAR 65PSI and the SPARE 80PSI. It has been my understanding with my other truck to be at max PSI for towing. Why does GMC show 65PSI?? What do you but in your tires when towing?
Truck is a 3500HD DRW and the Trailer is a 31ft fifth wheel, pin wgt about 2200lbs.
2011 Keystone Laredo Fifth Wheel 310RE
2012 GMC 3500HD Dually 4x4 Duramax/Allision
Ranger Smith
Wherever the rig is parked
When towing I run 80 rears and 70 fronts
Where I Am Now
Amateur Radio Operator KK9W ARRL VE FT DX2000
Steve and Joy
1999 Winnebago Ultimate Freedom
2011 RAM 1500 Laramie CC 4x4 Hemi
Yogi . . . The Yorkie
Kage . . . The Poodle
Cookie . . . The Chihuahua
Cooper . . . The Aussiedoodle
Bill1374
northern New York
My 3/4 I run 65 front 65 rear for towing, empty is 65 front 40 rear. My dually is 65 front, 60 rear and drop the rears to 35 when empty.
Bill
2011 Hitchhiker Discover America 345RSE
2006 Dodge quadcab,dually 2 wheel drive
larry barnhart
wenatchee. wa usa
We are running at the max when towing for GVWR. 80 lbs in rear tires with no problems on this truck or the 2001 3500 8.1 dually. hard to beat "no problems"
35 lbs solo for a dually seems very low.
chevman
chevman
2001 35 ft avalon alpenlite RK
prodigy
easyrider/reese airhitch
trailair center point suspension
JT Strong Arm Stabilizers
KSH 55 inbed fuel tank
Garmin 2720
scanguage II
TD-EOC
Induction Overhaul Kit
TST tire monitors
fly-boy
Los Angeles, CA
Way too much pressure- your tires will wear prematurely and you gain nothing but a bumpier ride at 80 pounds.
I would drop the pressure down in the back to 60 for 2200 pounds and 65 in the front. (a little more in the front since you only have two tires and not six)
My trailer is a lot heavier from a pin weight standpoint and the above has served me well with all of my drw trucks. I typically get 40k out of a set of tires.
2012 GMC 3500 Denali Duramax 4x4
2009 WW HKD with a big garage
A few toys
blt2ski
Kirkland, Wa
your tires at 80 lbs are good to over 10K lbs total. Reality is, most of us are at 7-8K on the rear, so 60-65 lbs should be good towing. Empty, you probably are like me, at around 3k-3500 lbs, so 40-50 lbs empty should also be plenty.
Marty
05 Chev CC D/A LS Dooley
3 Single axle utility trailers
Check RV.Net Blogs at: blog.rv.net
southernsky
Ponchatoula La.
I put mine at what the truck calls for. When towing 65psi all around, no problems so far...
2007 Ram 3500 DRW Mega Cab 5.9 CTD 4X4 (Fat Betty)
2012 Primetime Crusader 320RLT
PullRite SuperGlide,5th Airborne,Firestone RideRite
MARKW8
Akron OH
You have 4 tires to carry the weight. 65# is whats needed if the rear is at maz. load. You won't be near that. My door sticker says 65 also. Thats what I run with a 3000#+ camper on. 80# would be needed for 12k just on the rear.
Mark
ib516
Up here!
The tires can carry more weight with more pressure. They call for 65psi in each of the 4 rear tires because that is all that is needed to carry the rear GAWR (Gross Axle Weight Rating) which is likely just over 9000#. If each tire is good for say 3000# when at 80 psi, that equals 12,000#, so 80 psi is not needed and just adds to ride harshness. Go with what the door sticker recommends.
2010 Cougar 322QBS 5er
2007 Dodge 3500 SRW Megacab, 4x4, 5.9L Cummins, 3.73, 48RE auto
HYPERTECH MAX ENERGY or DIABLO PREDATOR tuning
MBRP 4" Turbo back
Scangauge2 for Boost, Coolant temp, Rail press & Trans Temp
Torklift Stable Loads
45Ricochet
North Idaho
I agree with the previous 5 answers. I run 60-65 towing and 45 empty on the rears. 65 front 100% of the time.
06 Ram 3500 CC LB Laramie 4x4 Dually 5.9 Cummins Smarty Jr 48RE Jacobs brake
GVWR 12,200 RAWR 9350
06 Grand Junction 34' High profile 15500 GVWR 3200 pin Mor/ryde 5500 Onan genny Dual A/C Wet bolts
27' Hallett 502, 500HP
