RV.Net Open Roads Forum: Towing: Hitch Recommendations Please
Search only in Towing
Open Roads Forum  >  Towing
 > Hitch Recommendations Please
StaceyE
Chicagoland
Posted: 02/20/12 06:33am Link  |  Print  |  Notify Moderator
We sold our camper and let the hitch go with it (old reese dual cam hitch). Complaints with the reese were that it required muscle to hook and unhook - fine for DH but I would like to learn to pull this trailer and be able to set everything up myself, I already help with the driving and do just about everything but hook and unhook. Also, DH felt like he needed to take off the bars to drive through the campground in order to made any tight corners and back into our spot easily - would be nice to not have to do that.
Towing has not been an issue since we upgraded our truck to a Chevy quad cab, diesel dually, so we're not worried about the truck handling the new trailer. What we bought is a Sunset trail that is 34' long and 6300 lbs with a tongue weight of 790 lbs. We would like a WD hitch with sway system that keeps the trailer safe and is easy to hook/unhook.
Any suggestions? (And I would love the Hensley Arrow, but it's so far out of the budget that it isn't an option - no matter how great they are). Thank you!
Tom and Stacey
DD Nikki (14) and Kate (9)
Wrigley, our big black dog
APT
SE Michigan
Posted: 02/20/12 06:44am Link  |  Print  |  Notify Moderator
1000 pound Equalizer or 1200 pound Reese. No need to remove the bars in the campground other than noise. My 3 year old could snap up the bars on my Reese dual cam if I let him. The trick is put the tongue on the ball, then raise the tongue jack. It is easier with a power tongue jack. . Then snap the WD bars and raise the jack.
2012 VW Passat TDI
Kanyonkitty
Gerrardstown, WV
Posted: 02/20/12 06:53am Link  |  Print  |  Notify Moderator
The Reese dual cam is extremely easy to hitch/un-hitch, when you use the tongue jack. After putting the coupler on the ball, use the tongue jack to raise both the tongue and the back of your TV. You can then snap up the WD bars by hand, with ease. As far as tight maneuvers while the bars are on.. These hitch setups are made for turning! There is no reason to take the bars off, unless it just gives you a warm and fuzzy feeling inside. We used to have a camera mounted above the hitch and I could watch the dual cam system in action. It was interesting to see how it works, when you are driving/turning/backing. Just had to be in the passenger seat, while watching the show...
If your DH has any questions, please tell him he can PM me..
Deep wedgewood blue '99 7.3L PSD F-350 Super Duty crew cab long bed dually or wedgewood blue '97 F-350 7.3L PSD crew cab longbed SRW, Member: Sunlineclub.com Rescue a retired Greyhound, greyt calm low maintenance traveling companions
Ron3rd
Upland, CA USA
Posted: 02/20/12 06:56am Link  |  Print  |  Notify Moderator
X2, if you're having to "muscle" up the WD, you're doing it the hard way. When you put the tongue on the ball, don't drop the jack down much. Same when you unhitch, raise the jack quite a bit and it takes very little effort to get the WD bars off.
2004 Aljo 250LT
Eaz-Lift WD Hitch
Single Friction Sway Control
Prodigy Brake Controller
Honda EU2000
StaceyE
Chicagoland
Posted: 02/20/12 07:02am Link  |  Print  |  Notify Moderator
Don't know if this makes a difference or not, but our other trailer was 20 years old and the hitch came with it. Not sure on the hitch age, but was at least 10 years old. It might be that my DH was doing it the hard way, or it might be that the hitch was old and worked differently? Not sure. Anyway, we want to get something new, safe, economical and easy to use. Have to chuckle a bit if he was doing it the hard way for six years!
Thanks, Stacey
eric james
Sioux Falls, SD
Posted: 02/20/12 09:08am Link  |  Print  |  Notify Moderator
Looks like he was doing it the hard way for six years.
A power tongue jack makes a world of difference.
I think the Equal-i-zer 4 point is the easiest hitch to use.
(I have a Dual Cam myself)
2009 Keystone Passport UL 290BH
2003 Ford Expedition EB 5.4L/3.73
skipnchar
Topeka or somewhere else
Posted: 02/20/12 10:20am Link  |  Print  |  Notify Moderator
Install an electric tongue jack and take all the need for using muscle out of the equation. If it's difficult to latch just jack up the rear of the attached vehicle a little higher. ANY weight distributing system that you can latch up EASILY is not transferring enough weight to make it worth using.
mkirsch
Rochester, NY
Posted: 02/20/12 10:41am Link  |  Print  |  Notify Moderator
Thanks, Stacey
He's been doing it the hard way for six years.
Reese Dual Cam is the same basic design today as day 1. Hitching technique is the same, and is the same as any conventional trunnion or round bar WD hitch.
2002 Chevy 3500 DRW 8.1L/Allison
2000 Palomino B1500
...and the reason why I need a DRW to haul a Palomino:
2004 United 7x14 tandem axle enclosed toy trailer
2011 PJ 8x20 7-ton deckover equipment trailer
Dick_B
Palos Heights, IL USA
Posted: 02/20/12 01:18pm Link  |  Print  |  Notify Moderator
The only time I remove the bars is when I unhitch.
Dick_B
2003 SunnyBrook 27FKS
2011 3/4 T Chevrolet Suburban
Equal-i-zer Hitch
StaceyE
Chicagoland
Posted: 02/20/12 04:11pm Link  |  Print  |  Notify Moderator
Jack it up before removing the bars, got it.
Now, which hitch do you recommend for our truck/trailer size combo that is easy to use and pulls well. Favorite brand, style, etc.?
Thanks!
