RV.Net Open Roads Forum: Tech Issues: attwood water heater
 > attwood water heater
boatms03
Groves, Tx
Posted: 02/21/12 05:12pm Link  |  Print  |  Notify Moderator
I have an attwood water heater model GC6AA-10E. my question is when i turn on the gas switch inside the heater lights, and then goes back out. a few seconds later it will light again, and then go back out. it will do this three times then a little red light comes on next to the switch inside. I can turn the switch off then back on and the heater will usually light and stay on to heat the water in the tank. once it shuts off it will not relight on its own. what could be wrong?
2009 Dodge Ram 2500 diesel
2007 Jayco Octane T26Y
2011 Polaris RZR S
Ka Ron
Kelowna
Posted: 02/21/12 05:26pm Link  |  Print  |  Notify Moderator
I had same problem and it was the circuit board.
Join Us For A Trip Down The RV Highway
Old-Biscuit
Across the USA
Posted: 02/21/12 06:15pm Link  |  Print  |  Notify Moderator
The following is a list from Atwood......Lock-out conditions (red light)
Low voltage---------Correct power supply - 10.5 VDC minimum
Poor electrical ground----------Secure electrical ground
Electrodes out of flame pattern ------Re-adjust electrodes
Electrodes sparking to screw fastening burner to flue tube-----Adjust electrodes away from screw
Dirty electrodes ----------Clean electrodes
Partial obstruction in main burner ---------Clean main burner
Partially obstructed main burner orifice----Clean main burner orifice or replace
Improper air adjustment --------Adjust main burner air shutter approximately 1/4 open
Flame spreader on main burner out of adjustment ----------Adjust flame spreader so that it is square to the end of burner tube
Manifold not aligned with main burner ----------Re-align solenoid valve with main burner
Partially opening solenoid valve -------Replace solenoid valve
Defective circuit board-------------Replace circuit board
Cheap fixes first......
Good ground
Clean burner tube
Clean burner orifice
Clean thermocouple....spark probe (1/8" gap between spark & ground rod)
Clean the connection for edge connector on circuit board....eraser
Check voltage to gas valve (10.5V DC to 13.5V DC with another 12V appliance on)
boatms03
Groves, Tx
Posted: 02/21/12 06:24pm Link  |  Print  |  Notify Moderator
thanks old-biscuit, I was going to do some additional checking before I bought a circuit board. I acts like a bad thermal couple on a home water heater or furnace. I pulled the igniter and cleaned the electrodes. When it does light it has a good blue flame, no yellow or white in it.
Alpenliter
Fulltimer: Wherever we are!
Posted: 02/21/12 11:24pm Link  |  Print  |  Notify Moderator
Had the same problem on mine and it was a bad solenoid valve. Only problem is you can't buy just the solenoid, they want you to buy a whole new gas valve.
My first Wife Linda, 45+years
2004 F-450 CC, DRW 6.0 Classy Chassis Upgrade
Bulletproof Diesel upgrades
1997 33' Alpenlite
400 Watts Solar
Lifetime Good Sam Member #39644174
Escapees SKP#89882
Vietnam Vet '67-'68
Extreme Makeover RV Style!
boatms03
Groves, Tx
Posted: 02/22/12 04:58pm Link  |  Print  |  Notify Moderator
is there a way to test the solenoid valve?
Kirk
Livingston, Texas.
Posted: 02/22/12 07:37pm Link  |  Print  |  Notify Moderator
About the only way is to monitor the voltage to the valve while you do this. If the gas flame stops and there is still voltage to the valve, then the valve is closing again. It is also possible for the solenoid to come loose. You can check that by removing the valve from the system and then just supply it with 12V power to open and monitor if you can put compressed air through it over a period of time.
I would be very slow to change the circuit board without some trouble shooting that points to it. A more likely cause is the spark probe which is also what monitors the sensing of the flame. If it is failing it will tell the circuit board to turn off the gas and the gas valve will loose 12V power. They are easy to replace and cost about $30.
Before you start to just through parts at it as some suggest, go to Bryant RV and down load a copy of the service manual. With that and a good meter you should be able to narrow things down.
Good travelin! ........Kirk
Professional Volunteer
Fulltimer for 11 years,
URL: www.adventure.1tree.net
Ka Ron
Kelowna
Posted: 02/22/12 10:05pm Link  |  Print  |  Notify Moderator
The most miss diagnosed thing with a gas appliance is the gas valve.
Yes, they do go, but the symptoms you have is not the gas valve.
Save yourself a lot of time, replace the circuit board.
An old retired Gas fitter....
John&Joey
Some Location
Posted: 02/23/12 07:01am Link  |  Print  |  Notify Moderator
Kirk wrote:
...I would be very slow to change the circuit board without some trouble shooting that points to it. A more likely cause is the spark probe which is also what monitors the sensing of the flame. If it is failing it will tell the circuit board to turn off the gas and the gas valve will loose 12V power. They are easy to replace and cost about $30.
Kirk is spot on.
The board will either work or not. It's usually not something that is so hit or miss. Download the manual and do the trouble shooting. It may be something so simple as a dirty connection, or a bad ground.
Sometimes replacing a board will make it all better when in reality it was the connection on the board. The new board will have nice new clean connections making the buyer think that the old problem was the board.
RJsfishin
Winston Or.
Posted: 02/23/12 07:12am Link  |  Print  |  Notify Moderator
My board WAS a hit and miss, long after thoroughly cleaning every connection.
And it seemed ambient temp changed the hit and miss also.
Rich
'01 31 ft Rexall Vision, Generac 5.5k, 9245 conv, 400 watt inv, 2 12v batts, ammeters, KingDome/sat, Two Oly Cat heaters, and towing a '05 Jeep Liberty, or sometimes towing a Lowe bass boat.
