RV.Net Open Roads Forum: Class A Motorhomes: Roof Air unit not working
 > Roof Air unit not working
vladen
Louisiana
Posted: 02/21/12 09:43pm Link  |  Print  |  Notify Moderator
I think you said your switch had three positions wonder if yours is supposed to be in the "off" positiion for the gen
Vlad's busy workings
All hope is gone
jimco205
Central Alabama
Posted: 02/21/12 10:19pm Link  |  Print  |  Notify Moderator
not sure, will have to check it tomorrow.
old guy
Oregon (pronounced Or e gun)
Posted: 02/21/12 10:23pm Link  |  Print  |  Notify Moderator
by pass the switch to see if it's the switch
vladen
Louisiana
Posted: 02/21/12 10:38pm Link  |  Print  |  Notify Moderator
well next would be check if its getting power in the line. You might can pull the cover and filters off on the inside and see a regular plug in that you can just unplug the AC and plug a light in and see if your getting power at least that far. Then you could actually blame the AC itself.
Tinstar
McKinney, TX
Posted: 02/21/12 11:18pm Link  |  Print  |  Notify Moderator
Typically a start capacitor is the cause of one quitting like that. You can troubleshoot like others have said but if it doesn't work go to the roof and take the A/C shroud off. Look for a couple of capacitors that might look something similar to ONE OF THESE. Mine are about your model year vintage and they are silver about 4 inches tall and round. Two heavy wires go to each one. If a capacitor is bulging it is likely bad but might be bad and not bulging. WARNING!!!! WARNING!!!! WARNING!!!! A capacitor stores electricity to start the motor so it may be CHARGED and it will hurt you if you touch the poles. DON'T TOUCH unless you know how to discharge the capacitor
They are cheap and easily replaced.
Never pass up a chance to go somewhere
1995brave
San Antonio, TX
Posted: 02/22/12 05:51am Link  |  Print  |  Notify Moderator
First thing to check is your circuit breakers. Turn them all off and then back on, don't forget the generator. One of them is for the front air conditioner.
teleman2
melbourne
Posted: 02/22/12 05:54am Link  |  Print  |  Notify Moderator
Are you using the gen. for ac? If so do any outlets have power If not check the breaker on the gen. There are 2 breakers on the gen. one controls the power for the rv. plus front ac . the other controls the rear ac.
Scott & Jill
Posted: 02/22/12 09:03am Link  |  Print  |  Notify Moderator
Are you trying to run both AC's at the same time or indivisibly some units you can only run one at a time? And are you running from generator or outlet.
Life is too short; enjoy it the best way possible
jones4110
Champlin, MN
Posted: 02/22/12 10:54am Link  |  Print  |  Notify Moderator
X2 on capacitor
Joan and Bruce
05 Excursion 39L
powered by 350 KittyCATS on a Spartan
2010 Traverse LT toad (Blue Ox & Breakbuddy)
...and a "road dog" named Max and his gabby sister, Abby.
"May the wind be always at your back and your destination the one you chose"
gvisnic
Littleton Co
Posted: 02/22/12 10:45pm Link  |  Print  |  Notify Moderator
We had a similar problem with our ac and it turned out to be a bad thermostat. Replaced and everythign was a-ok. Had to have a service tech check it out for us.
