mmartinfan
sun city center, florida
Does anyone know if you can convert a gas generator in a motorhome to propane? Do you think it is cheaper to run a generator off your propane or your gas tank? Just wondering. Thanks
lwasouth
You will find that your generator will cost you about 50% more to run on propane.
Electronpusher
Southern Oregon
mmartinfan wrote: Does anyone know if you can convert a gas generator in a motorhome to propane? Yes Do you think it is cheaper to run a generator off your propane
No
There is less energy in a given amount of propane than gasoline--
However your generator engine will run very clean to the point that the oil probably won't even look used between change intervals--
ReM
Dick & Bette
and
Jedediah the Cat
2004 Journey 36G
Golden_HVAC
Fulltime, CA, USA
Gasoline has about 115,000 Btu's per gallon, so it gets poor mileage compared to diesel, at 135,000 Btu's per gallon. Propane is only 95,000 Btu's, and while it will burn a little more efficiently, you will still consume about 15% more fuel than with gasoline.
Many diesel motorhomes that have a LP generaor have a 20+ gallon tank, with some in the 50 gallon range, so that you can camp a whole week and not refill the propane tank.
Yes it is possible to convert a propane generator go gas or gas to propane. Hopefully the valves will have the required hardened seas from the factory, or you might need to rebuild the engine. It is also possible to install a 20 gallon frame mounted tank, expect the tank cost alone to be in the $650 range.
Fred.
msmith1199
Central, CA
I don't think I would do it just for the simple fact that it's easier to fill the gas tank than the propane tank. If you use the generator and other gas things a lot you will be having to find a place to fill the tank that much more often. I have a 30 gallon propane tank and I usually only have to fill it about once a year.
2004 National Tropi-Cal T-350, Class A, Triple slide, 330 HP Cat DP.
2006 Dodge Dakota 4x4 or
2002 Harley FLSTF Fat Boy on a Trailer or
2004 Polaris Quad on the Trailer
catallison777
West Columbia, South Carolina
msmith1199 wrote: I don't think I would do it just for the simple fact that it's easier to fill the gas tank than the propane tank. If you use the generator and other gas things a lot you will be having to find a place to fill the tank that much more often. I have a 30 gallon propane tank and I usually only have to fill it about once a year.
X2
2003 Damon Ultrasport 3873
Onan Quietdiesel 7500
Caterpillar 3126E
Allison Transmission 3000
Honda EU2000i
1992 Jeep Wrangler(Towed 4 Down)
bill h
coastal reconquista
It would depend on refilling. If refilling propane is easy, go for it. If refilling gasoline, by can or whatever, is easier, that is the way to go.
Generally, gasoline is more convenient to refill, but your situation, present and future, will dictate.
NOTE: Any incorrect spelling is intentional to prevent those annoying popups.
84 Barth 30Tag powered by HT502/Thorley/Weiand etc, Gear Vendors OD.
Siamese Calvin and Airedale Hobbes, 4WD Toyota toad
C-Leigh Racing
Nashville NC
As noted, the LP gen oil will look clean as new, as well as the insides of the engine, because there no blow by products from LP to gunk up the inside of the engine. You pull the engine down after years of use & it will look as though its only had a short test run, so that part of an LP gen is ok.
Lord help keeping the LP tank full though. You going to boon dock for a week, better have a tanker close by to keep her full.
Neil
workhardplayharder
Treasure Coast Florida
Will this help.
bluwtr49
Green Valley, AZ
A couple of things to think about.
Many places propane is WAAAY more expensive than gas or diesel.
If you do the conversion the value of you coach may drop considerably as few buyers want a propane gen set. When we were looking, I ignored every coach with a propane gen set regardless of make or price.
Dick
2000 40" DP Beaver Patriot Thunder Cat C-12 425 HP, 1550 Tq
1997 Jeep GC Limited ---toad
2008 Toyota Tundra Crew Max Limited TRD (Retired)
2009 Cougar 268 RLS ~8700 lbs road wt (Retrired)
2006 Jeep Liberty Turbo Diesel.....TV in Training
