RV.Net Open Roads Forum: Towing: 1500 Suburban
Search only in Towing
Open Roads Forum  >  Towing
 > 1500 Suburban
Ca_larsen
Illinois
Posted: 02/25/12 10:42am Link  |  Print  |  Notify Moderator
We are looking into purchasing a HT that has a Dry weight of 4475 / GVW of 5800 or 6000 and a hitch rate of 770.
The specs on are suburban(written on the hitch) says
500 lb hitch and towing 5000
What do we need to do to make this work, or can we?
Getting a new tow vehicle is not an option.
jerem0621
Tennessee
Posted: 02/25/12 11:03am Link  |  Print  |  Notify Moderator
The suburban 1500 has been made for over 30 years. We need more information before we can provide any solid Advice.
On your hitch are there any other numbers that give a higher rating when used as a weight distribution hitch?
We need to know
Year
Motor
Rear axle ratio
And the gvwr for your suburban.
Also the dry hitch weight will go up significantly loaded for camping.
Thanks
Tow Vehicle- 2008 F150, SuperCrew XLT, 2wd, 4.6 (248 HP, 294 lb ft tq)
Pro Series 550 Round bar hitch
Great pickup truck!
My experience towing heavy with a Minivan click Here
Ca_larsen
Illinois
Posted: 02/25/12 11:14am Link  |  Print  |  Notify Moderator
Sorry, my husband decided to take it to a truck dealer and see what they say!
Thank you!
skipnchar
Topeka or somewhere else
Posted: 02/25/12 11:20am Link  |  Print  |  Notify Moderator
Sounds like your Suburban has a Class III receiver. Replace it with a class IV and use a weight distributing system on the trailer.
Good luck / Skip
BenK
SF BayArea
Posted: 02/25/12 12:40pm Link  |  Print  |  Notify Moderator
Suburban is the longest running model/badge/name in automotive history. Just over
75 years and counting. Not the GMC version, which reset that linage and is now
only about 8-10 years old or so
What year Sub? Important as the receiver design changed from GMT400 (mine) to GMT800
and now changed again in the GMT900 platforms
All Suburban tow options that I know of came with a Class IV receiver
The GMT800 receivers should be replaced with a traditional receiver design.
About $150-$200 plus about 1 hours labor.
GMT900 is welded onto the frame and is part of the bumper system, so has crumple
zone responsibilities. Why it is limited to a 1,000 tongue weight in WD mode
So, need more info in order to help
What year?
What GVWR?
Optional OEM and after market equipment and modifications? Especially tire size
and if suspension lifted or not.
-Ben Picture of my rig
bikendan
Camano Island, Wash.
Posted: 02/25/12 12:57pm Link  |  Print  |  Notify Moderator
yes, don't pay attention to the receiver's numbers. that's specific to the receiver itself, no matter what vehicle it's on.
i agree that it sounds like a Type III, probably aftermarket, which means your Burb doesn't have the factory tow package.
need to know year, engine size, rear end ratio. you can take the VIN to a Chevy dealer to know if it has the factory tow package.
but with only a Type III, i seriously doubt it.
if it doesn't, you'll have to duplicate all the things a factory tow package comes with.
by the way, it's a hitch receiver that's bolted to the tow vehicle. a hitch is what goes into it. the trailer attaches to the hitch and the hitch attaches to the tow vehicle's receiver.
Dan- Firefighter">, Shawn- Musician/Entrepreneur">, Zoe- Faithful Golden Retriever(RIP">), 2014 Ford F150 Ecoboost, 2016 PrimeTime TracerAIR 255 w/Equalizer and Prodigy, and 5 Mtn. bikes and 2 Road bikes
Erie Tom
Willoughby, ohio
Posted: 02/25/12 06:18pm Link  |  Print  |  Notify Moderator
A 1500 subrban I believe is on a 1/2 ton frame. There is a 1/2 ton and 3/4 ton Suburban. This would dictate what you could tow. I would check my tow vehicle specs to see what I can tow comfortly before purchasing anything.
Erie Tom N8UAZ (Better Half Pat)
Ohio Winter Steelhead Country
25' Innsbruck 5ver
2003 GMC 2500HD 2x4. Extcab SB Duramax/Allison
Reese Kwik Slide Hitch
Prodigy
Ham radio listen to 146.52 simplex. HF 20M and 40M mobile
Retired and free as a bird">
 > 1500 Suburban
