RV.Net Open Roads Forum: Dinghy Towing: No Response from CoolTech??
Search only in Dinghy Towing
 > No Response from CoolTech??
SarahW422
Houston
Posted: 02/26/12 04:02pm Link  |  Print  |  Notify Moderator
I have been trying to contact CoolTech for a couple of weeks, by phone and email. No Response. I am wondering whether this is typical of their customer service as we were considering buying the wiring harness but have some questions before ordering. Has anyone bought from them lately? Thanks.
SailnSeagulls
New York
Posted: 02/27/12 07:06am Link  |  Print  |  Notify Moderator
I have not tried to speak to anyone at CoolTech but I did place an order online a couple of weeks ago. It arrived without any problem.
Larry
rmblaster
anaheim
Posted: 02/27/12 11:34am Link  |  Print  |  Notify Moderator
Having used the cool tech harness on my 2008 wrangler I can assure you there is nothing better out there and they do not use diodes its plug and play using factory connectors I know nothing of their customer service because I never needed it and as far installing it came with good instructions Im sure if you posted your questions you would get the answers you need their are a lot of cool tech users on here
Richard
2010 Bounder Classic 30T
2008 Jeep Wrangler Unlimited
SarahW422
Houston
Posted: 02/27/12 04:21pm Link  |  Print  |  Notify Moderator
Richard
Thanks, Richard. My main concern is that I've read in a few posts here and on other boards that a fuse must be pulled when using the CoolTech harness. I'm trying to find out if that is the case, because frankly I don't want to mess with fuses or anything else...I just want the simplest wiring solution that won't mess up my new Jeep. Thanks.
rmblaster
anaheim
Posted: 02/27/12 05:24pm Link  |  Print  |  Notify Moderator
I had to pull the iod fuse because 2008 had steering wheel lock and you had to leave key on so you had to power down the jeep I never had to pull the brake lite fuse because i used a relay instead my jeep brake lites would only work when my key was on
