RV.Net Open Roads Forum: Tech Issues: Question on switching from DirectTV to Dish
 > Question on switching from DirectTV to Dish
sd1209
elko
Posted: 02/28/12 04:39pm Link  |  Print  |  Notify Moderator
Currently have DirectTV....Looking to switch over to Dish......I currently have a portable dish on a tripod that is labelled "DirectTV" and I just take the box from the house, set up the dish at the CG using the "signal meter" screen on the TV and good to go wherever I am........Takes 5 mins and it has worked great across the country....
If I switch to Dish, is the procedure the same?? Just take the box from the house and set it up?? Can I use the same dish or do I need one specifically for Dish?? I don't have HD at the house or the MH.....
Steve and Liz
Fallbrook, Ca
Steve and Liz
Elko, Nv
2006 Gulfstream Independence 30' 3 slides....V-10...
2010 Wrangler w/Blue Ox Towbar, Baseplate and braking system
imgoin4it
Alamogordo, NM USA
Posted: 02/28/12 04:53pm Link  |  Print  |  Notify Moderator
Dish gets their programming from more than one sat so no it is not as easy as setting up an 18 inch dish as you can do with direct. You need an oval dish that sets the elevation, azmith and skew. then switch from one sat to the other. Not a detailed answer, but the best I can do. I have a friend that is considering changing from Dish to Direct because it is easier. Now if you want reception while moving and high defination etc, it get more complicated as far as the equipment , supplier etc.
Retired and loving it
Living in the Land of Enchantment
Traveling in 2007 Newmar KSDP
towing a Jeep Liberty
with a Blue Ox tow bar
Crazy Ray
Monroe,La
Posted: 02/28/12 04:54pm Link  |  Print  |  Notify Moderator
Steve, you have to have A DISH from Dish. JMO
RET ARMY 1980, DW Donna , "Tiny" (furkid) . Class A, 2007 Bounder 35E, Ford Chassis, 4 SAMS 6VOLTS,405W Solar,TriStar 45 Controller,1750W INVERTER, YAMAHA 2400, TOW: Honda CRV. READY BRAKE. "Living Our Dream". NASCAR FAN 14,18,20,11 LOVE CO & NM
Ranger Smith
Wherever the rig is parked
Posted: 02/28/12 05:45pm Link  |  Print  |  Notify Moderator
Steve and Liz
Fallbrook, Ca
WHY . . . Direct is easier to setup. Dish requires changing satellites when changing channels so you need to be aligned with all of them.
Where I Am Now
Amateur Radio Operator KK9W ARRL VE FT DX2000
Steve and Joy
1999 Winnebago Ultimate Freedom
2011 RAM 1500 Laramie CC 4x4 Hemi
Yogi . . . The Yorkie
Kage . . . The Poodle
Cookie . . . The Chihuahua
Cooper . . . The Aussiedoodle
tandkj
Full timer
Posted: 02/28/12 07:34pm Link  |  Print  |  Notify Moderator
JMHO - stay with Direct easier to setup and use, more channels for the money.
Tis another fine day to serve in and for the glory of the Corps. Every day is a holiday and every meal a feast.
08 Camelot
07 Ranger Toad
One Golden Retriever at the Rainbow Bridge and a new one traveling with us.
2ndhom
Eugene, Oregon
Posted: 02/28/12 07:38pm Link  |  Print  |  Notify Moderator
Times 2 !!!!!
shepcal
Oakhurst,California
Posted: 02/28/12 08:54pm Link  |  Print  |  Notify Moderator
I have Dish and Toyhauler has it's own receiver, while parked at home Dish is set up. It's always ready (have TV while loading, in case race is on). Costs $5 a month.
When I get out in the desert, most of the time only takes 10 minutes to zero in. 3 times in last 8 years took longer (too many beers?) and thought about the automatic cubes,but $600 buys alot of beer so haven't done it yet.
Shep
monkey44
Cape Cod, MA and JAX, Fla
Posted: 02/28/12 09:15pm Link  |  Print  |  Notify Moderator
Anyone know if VuCube does both?? It's an older version - '1000' I think
Monkey44
Cape Cod Ma & JAX Fla
GMC 2500 4x4 Sierra X-Cab
2008 Lance 845
2002 Angler 8B
Back-country camping fanatic
ejforwood
Littleton (Denver) Colorado
Posted: 02/29/12 12:25am Link  |  Print  |  Notify Moderator
2ndhom wrote:
Times 2 !!!!!
X 3 !!!!!!!!!!!!!!
Jerry & Dottie
98 Bounder 34V, 99 F-53 Ford V10 chassis
06 Saturn VUE 4I
wd
SoCal
Posted: 02/28/12 07:44pm Link  |  Print  |  Notify Moderator
If you go with DISH you might want to look into the "tailgater". I have one and I sit it outside, move the handle anywhere toward the south and an internal device will find the satellites. Never had a problem locating satellites. The cost is about $350, weighs about 10 lbs. Little expensive but it works great.
