billtex
RI
BCBigfoot106 wrote: If your camper hangs over, it's a bit of a hassle. So I put mine in my wheel wells. I usually check my tire pressure and air bags before departure. So this makes it more convenient. This also makes for a very short routing of the lines.
Same here.
2006 Chevy D/A CC
Adventurer 810WS
25'Airstream Excella
"Good People Drink Good Beer"-Hunter S Thompson
bka0721
Republic of Colorado
If you are going to install gauges and switches on your dash, be sure to think about where you place the controls in regards to where your knees or thighs might contact during the possibilty of a collision.
I have seen some serious injuries to knees and upper leg injuries from impact of Off Road Light switches, Brake Controlers and possibly compressor regulators gauges. That is why the lower dash is elongated and pointed downward to help body parts miss items behind the steering wheel and other physical items.
08 F550-4X4-CrewChas-6.4LDiesel-206"WB GVWR17,950lbs
09 Lance 1191
600w Solar~8-6vGC2 928AmpH~Tri-Star45/4 MPPT
Xantrex 2000W
300w Solar~2-6vAGM 240AmpH~Tri-Star45/4 MPPT
Xantrex 1500W
08 BMW R1200GS Adventure
09 7X14 Enclosed Haulmark Trailer
DiscoChicken
Lawrenceville, GA
I put my valves in front of the rear wheel well. There was all ready a hole. A compressor would be awesome, but I don't have one. My buddy has his next to the license plate. Pain to get to that if your tc hangs over.
FYI: I installed my own airbags. By the time I bought the tools to do it, I could've paid for the install. Took a few hours. One bolt was almost too short to get a thread bite. I conquered though.
Adventurer/Ford
HarleyEnough
PA
I installed the AirLift wireless compressor. It has a remote control with LCD read out for pressures and automatically keeps the bags at the set pressure. You can stand 20ft from the truck and just hit the up button until the truck is level. Has presets too once you find the right pressure you can just hit the preset button and load up.
Works well since I also pull a dump trailer and deckover which is always loaded at different weights.
2011 Dodge Ram Laramie 3500 Crew Cab Long Bed SRW
2006 KZ Sportster 41GKx2 Toy Hauler
KZOwnersForum.com
NorthernLimits
Michigan
kitesurfer
nor cal
Mine are on a mounting plate on the rear tow hitch. It is a bit of a hassle in that location when the camper is on, but I can use my bicycle pump since the valvles are close to the ground
sabconsulting
High Wycombe, UK
Just installed my airbags today. I've included some pictures of where I ran the air lines:
Airbag installation report
Steve.
'07 Ford Ranger XLT Supercab diesel + '91 Shadow Cruiser - Sky Cruiser 1
'92 Suzuki Samurai 4x4 1.6
'09 Fiat Panda 1.2
'10 Citroen DS3 1.6 turbo
billtex
RI
A question for the folks that put them behind the fuel fill door; how do you monitor when the bags are lifting off the over load?
One of the main advantages of having them in the wheel well is you can see the amount of lift as you fill the bags...
Also, I check tires and air bags just prior to hitting the road any way.
I had considered a compressor with in cab controls, etc...I figured I could add this after if we needed to. After 5 yrs, I have found I fiddle very little with the bags once they are set...so I am glad I did not spend the $ for the in cab set-up. That is 2x the $ of the air bags.
For us it is set/forget.
B
scolew325
salem or.
I installed mine individually behind the fuel doors, one behind each, I can get to them very easily at any time and don't have to crawl under the camper to do it. Obviously the dealer doesn't have a TC.I also used electrical wire tubing to run the lines through to eliminate any rubbing that might happen.
Scott T. Lewis
