RV.Net Open Roads Forum: Fifth-Wheels: Engine Hoist to remove hitch
 > Engine Hoist to remove hitch
Page of 5
garysol
Avon Ohio
Posted: 03/06/12 06:10am Link  |  Print  |  Notify Moderator
bigdon68 wrote:
Check out MY PICTURES below
Thanks Don.....
2008 Dodge Ram 3500 6.7 CTD SRW, Pullrite Superglide 18k.
2012 Komfort 3530fbh 5th wheel with Ground Control
towingaload
Posted: 03/06/12 06:53am Link  |  Print  |  Notify Moderator
usmohls2@yahoo.com wrote:
MTPockets1 wrote:
Vulcaneer wrote:
I just lift it out by leaving it hooked to the pin-box and raising the front elevators. The only strength that uses is one finger pushing a button.
This is the way to do it!
2X
Same here.
I leave my SuperGlide hitch attached to the pin box. I use a turn buckle at the rear of the hitch to level it while raising it from the truck bed.
ford coupe
home
Posted: 03/06/12 07:02am Link  |  Print  |  Notify Moderator
I use a hydraulic engine hoist(cherry picker) whell it into corner of garage out of the way,use an old tie down strap wrapped around hitch,takes about 5 min. to remove
07PSDCREW
Berlin Ma
Posted: 03/07/12 06:30pm Link  |  Print  |  Notify Moderator
Reese 16k round tube slider.... I lift it out of the rails and slide to the back of the truck and then give it the ole' heave ho to a furniture dolly on the ground. After reading here, I'm going to harbor freight to get the hoist to attach to the garage door header.
2007 Ford F350 6.0 CC SB
Fully bulletproofed/EGR/ARP Studs
Reese 16k round tube slider hitch.
2000 Damon Hornet 2850BH 5er
Days camped 2011= 34 2012= 46
justacanstacker
West Haven
Posted: 03/08/12 11:34am Link  |  Print  |  Notify Moderator
I have a 2000lb crane from Harbor Freight. Put an extension bar on it. To be able to reach in the bed while tail gate is on. I can pick up Pull-rite Superglide by myself! I am 5 foot female. Install and take out hitch every spring and fall. Would post pics. Not sure how to do it.
* This post was edited 03/09/12 07:13am by justacanstacker *
soling2003
Federal Way, WA
Posted: 03/10/12 09:53pm Link  |  Print  |  Notify Moderator
I use an engine hoist too, with wheels on it. I don't need a dolly, just extend the lifting bar out, pin it, and move the hoist in behind the tailgate. Im sorry, but I don't have any pictures. I use some 3/8" kevlar line with nylon cover wrapped around the hitch. I can easily move it around so that it lifts level. Eventually I'll get around to a premade cable or chain. I can put it in the corner of the garage very easily.
Good luck.
DW and 2 dogs
2011 Ford F350 Dually LB 4x4 CC 6.7 diesel
2007 Grand Junction 35TMS
Peterson 37(just sold) T-37 R/C Sailboat at home
msjdbman
SW Michigan
Posted: 03/11/12 06:31am Link  |  Print  |  Notify Moderator
I`ve got a cherry picker and could use that, but I use my loader tractor with pallet forks. I pop the hitch out of the rails with a bar, and then lift it out with the forks, set it on a small pallet I attached wheels to, and wheel it out of the way. My hitch is a Reese 16K Slider.
2008 Duramax/Allison LT2 Crew cab Standard Box. Hellwig Air Assist.
2003 Coachmen Chaparral 295 IKS
johnvb
Virginia Beach /Virginia/USA
Posted: 03/11/12 07:32am Link  |  Print  |  Notify Moderator
CactusJohn wrote:
I use an inexpensive come-along hoist attached to a hook that is screwed into my garage door header. (I access the hook through the gap created between the bottom edge of the door and the header when the door is open.) I attach a chain to the two eye bolts that I permanently attached to the hitch via pre-drilled holes. I then raise the hitch off the rails, move the truck out of the way, and lower the hitch onto a furniture mover.
Ditto here, works like a charm, for my 16k (non-sliding) Reese. And a comealong is a nice tool to have around the house for other chores, such as stump pulling.
I connect the hook of the comealong to a large HD eyelet bolt, nut and washered to a pipe flange that fits in the pin latch.
Trailer Trash 2
Santa Fe Springs, CA
Posted: 03/11/12 11:34pm Link  |  Print  |  Notify Moderator
here is what I used I got it at Horbor Freight on sale good for 200 lbs or 400 with a snach block.
Don & Georgia
AKA: Trailer Trash 2
Real trucks don't have spark plugs.
2009, Dodge, 3500, Q Cab, Cum/Diesel, D.R.W.
Pulling a Super Fine Montana 2980RL
Page of 5
