DKean
Mays Landing NJ.
I use Fire Fox browser. I have a pop up blocker. It works on everything except the fire fox pop up that asks me to up grade to the latest version of fire fox. The newer version says it won't support Google tool bar so I don't want it.
Is there any way to stop this pop up with out using IE or do I just have to live with it?
2006 F350 CC LB 6.0 diesel dually. 2006 Cedar Creek fifth wheel. Six 6 volt golf cart batteries,3000 watt inverter. Mountain Master generator in truck bed remote start. Automatic satellite dish.Air suspension on truck and trailer.Level up with 6 jacks RC
CincyGus
Cincinnati
First, check the options or settings in firefox and see if there is a option to notify you if a new version or upgrade becomes available. Don't use FF so not real familar with if that is in there but often software has these type options to turn it off.
If you can't find it in there, Try running msconfig by going to your start menu and typing msconfig.
See if there is a reference to it in the startup items tab.
Sometimes software manufactures put one in there labeled "...reminder" such as FFreminder or firefox reminder. If there is any reference to firefox in there, un-check it and save then reboot your pc.
Those would be the first two things I would do to try to eliminate it. If that doesn't work, try searching their suport forum. I'm sure your not the first that it has irritated and that has asked for help in turning it off.
Good Luck!
2011 Silverado Crewcab 4x4
2012 Passport 238ML
Hope your travels are safe and the friendships made camping are lasting.
denverhank
Iowa
Tools/Options/Advanced/Update tab. Under Firefox updates, turn off check for updates.
2003 Ford F-250 King Ranch 4x4 6L PSD
2012 Jayco 31.5FBHS
DW and an African Grey chatterbox
retired IT tech
Wherever I happen to park
Gee... I don't use the Google tool bar.
Under options I think (Tools | OPTIONS | Advanced | Update)
Choose the one not recommended (never check for updates)
There is a search engine or two "Add-On" that lets you add ANY search engine to the search engine bar on Firefox. It can add Google search without the need for the google tool bar, or Yahoo search or BING search or ____ search (you pick an engine) IT is called "Add to search bar" if I'm not mistaken, You might also want Orginize Search Engines add on,, This lets me do a Google search easily and quickly WITHOUT the GOOGLE tool bar.. Frankly I have enough tool bars I do not need more.
ChopperBill
Colo
I have FF 10.0.2. And use the Google tool bar. The auto fill no longer has credit card info. I think that was a security factor when FF initially stopped allowing their tool bar.
wittmeba
Virginia
Check this:
And also check in your if Vista Programs Installed (Control Panel/Programs and Features) for Mozilla Maintenance Service - uninstall it.
I was born in Great Falls, Mt. My parents moved when I was 5. I found them when I was 10 - they were in California.
Firefox® 21.0
Log home images - Updated 05/19/2013
