RV.Net Open Roads Forum: Tow Vehicles: How 'bout this load...
Search only in Tow Vehicles
 > How 'bout this load...
Madhatter1
Madeira Beach FL
Posted: 03/07/12 06:28pm Link  |  Print  |  Notify Moderator
Is that why my wife calls me Hot Shot?!?!
dreeder
Castle Rock, Co
Posted: 03/07/12 06:40pm Link  |  Print  |  Notify Moderator
agesilaus wrote:
Might be hard to do in Florida since we have real weight police driving the highways. I see them stopping trucks all the time with their portable scales.
Rather or not a commercial motor vehicle is over its GCWR or GVWR isn't the weight police's primary concern, they are concerned with the maximum allowable weight on the roadway itself, particulary the allowable weight on each axle that is on the roadway. If they are over any of these weights, the driver gets to off load some merchandise to get under the maximum allowable weight or shift its load around to take weight off a particular axle simply to prevent road damage.
* This post was edited 03/07/12 07:07pm by dreeder *
chadsalt
GA
Posted: 03/07/12 07:46pm Link  |  Print  |  Notify Moderator
Does anyone else want to bet that fellow (and thousand others) who make their living hauling loads like that 24/7/365 did NOT check in with rv.net as to what is "safe"??????
dodge guy
Bartlett IL
Posted: 03/07/12 07:47pm Link  |  Print  |  Notify Moderator
The first car is approx. 3k lbs. the explorer is roughly 5k and i guess the truck is just over 6k. Figure he has at least 3k on the hitch maybe more like 4k. Maybe overweight, but i wasnt there when he weighed it.
Wife Kim
Son Brandon 11yrs
Daughter Marissa 10yrs
Dog Shadow
07 Cherokee 32B
02 Excursion 4X4 V-10 4.30 gear 5Star tuner Y-pipe mod Hellwig sway bar
Reese HP dualcam Prodigy brake controller
A bad day of camping is
kofire
t-town
Posted: 03/07/12 07:37pm Link  |  Print  |  Notify Moderator
Terryallan wrote:
It's called a "Hot Shot", and it's legal in every way. A Hot Shot, Because when it's a small load, and it has to be there fast. You put it on a Hot Shot.
Exactly. The thorn in the weight police's side. Totally legal
ls1mike
Bremerton
Posted: 03/07/12 07:42pm Link  |  Print  |  Notify Moderator
Now that right there is funny!
Mike
2002 Silverado 2500 HD 6.0 Crew Cab long bed
2012 Passport 3220 BHWE
Me, the Wife, two little ones and two dogs.
45Ricochet
North Idaho
Posted: 03/07/12 08:08pm Link  |  Print  |  Notify Moderator
Some states if not all require your DOT numbers posted on the side and you will need to exit onto scales just like the big rigs. Many states have a pay per GVW whereas your tags need to reflect the increased weight. Like a famous person once preached to me "you can tow a 15k lb RV with a Yugo " and still be legal, in some states anyway
This guy should be fine with 5 axles and 12 tires , as far as weight and law enforcement.
06 Ram 3500 CC LB Laramie 4x4 Dually 5.9 Cummins Smarty Jr 48RE Jacobs brake
GVWR 12,200 RAWR 9350
06 Grand Junction 34' High profile 15500 GVWR 3200 pin Mor/ryde 5500 Onan genny Dual A/C Wet bolts
27' Hallett 502, 500HP
benalbert
ND
Posted: 03/07/12 08:09pm Link  |  Print  |  Notify Moderator
And the trailer axles can carry 21k. So what's the problem. Look at my sig pic. Thats 13,500 on the trailer... perfectly legal and I only have a SRW.
Oh, yeah and the Dodge with the car hauler is a commercial vehicle. Must follow all applicable rules and regs. Logbook, USDOT #, stop at scales etc.
03 F350 CCLB SRW 6.0
00 KZ Sportsmen 951
dreeder
Castle Rock, Co
Posted: 03/07/12 08:22pm Link  |  Print  |  Notify Moderator
I agree, these loads run up and down the interstate all day long in Colorado, no problem. I always thought it might be a good post retirement gig...
Terryallan
Foothills NC
Posted: 03/07/12 08:45pm Link  |  Print  |  Notify Moderator
You weren't there. But the DOT was, and they said he was legal. and they will be there the next time as well. He'll be legal then too. Thousands of people make their living with these vehicles. If it was illegal. they could not do it.
Comercial trucks are actually allowed 15,000 lbs per single axle, and 34500 lbs per tandem axle, Not sure about triple axles, But I bet it's more. That's one of the reasons RVs are not required to stop in weightstations. They know we will never load our rigs heavy enough to be over the DOT weight laws.
* This post was edited 03/07/12 08:54pm by Terryallan *
Terry & Shay
Coachman Apex 288BH.
04 F150, 5.4, Lariat SuperCab
Lazy Campers
