MTPockets1
Send jayco a link to this thread as well....
2012 3055RL Big Horn - Dexter 7000 lb axles - G rated LT Tires
MorRyde, Genset, Dual Panes, 2 A/C, Yeti Package
2013 F350 DRW 4x4 Crew King Ranch
Turbo Diesel Dude
Green Mountain, NC
Years ago when I had a Savoy SL made by the old Monaco Co. I was told that my roof leaked because I failed to perform the "roof maintenance"/inspection portion which I had. Turned out the roof wasn't fastened to the walls properly by the factory. Ended up being a "buy back". Leaked so bad, it'd take three bildge pumps to keep it dry. Could see wide open cracks that were 1/4" wide in three 10 foot sections up there. Junk. JMHO
charles weidman
RECVEH2005
Green Valley, AZ, USA
I'm in the market for a new fiver within the next few months. This posting has reduced my list by one manufacturer; I will NOT consider any fiver made by Jayco! Their response to your roof situation is unacceptable!!!
Mike
Mike & Donna Scheer
2013 GMC SRW Crew Cab 3500 short-bed D/A
2013 HitchHiker Discover America 300 FK
57 Panhead
Central Valley Calif.
RECVEH2005 wrote: I'm in the market for a new fiver within the next few months. This posting has reduced my list by one manufacturer; I will NOT consider any fiver made by Jayco! Their response to your roof situation is unacceptable!!!
Mike
Mike;
While I'm really unhappy with Jayco's position regarding my roof, we really do like the trailer. I guess what people should take away from this is inspect, inspect, inspect!!! And if you see something you don't like or something you can't live with, then move on and find another unit. If you spend enough time on the various forums out on the internet you'll find there are a lot of brands with problems from the entry level to the high end. Will I buy another Jayco? At this point in time I really can't answer that, check back with me in a year.
Steve
Retired Teamster
2012 Jayco Eagle Superlite 31.5RLTS
07 F250 PowerStroke
U Y B
Us out West
Let's see...last night we stayed in......
Good response Steve.
Although isolated, from what I have read in this and other Forums, it is still a concern but not a reason to not by from any manufacturer...including Jayco.
Best of luck getting your issue resolved to your satisfaction.
Our Trip Journal
2012 Jayco Pinnacle (View)
36KitchenPantryTripleSlide
MorRyde pin box and suspension
Curt Q24
Dual Pane windows
Auto Levelers
2 AC's
And more...
2009 Silverado 3500HD 4X4 (View)
CC,
Dura-Max 6.6/Allison
LB
DRW
American Tank 65 gal. Aux Fuel
RECVEH2005
Steve, My failing is that I don't have any patience with shoddy workmanship and/or poor customer service. I guess I'd better get over it if I'm going live thru another RV purchase
I do hope you have many good camping seasons with your new trailer. Just a suggestion: if you're through going back and forth with Jayco over the matter, you might cover that protruding screw or nail bump with an Eternabond patch or at least carry one along with you. They are available in a six-inch square size and REALLY stick well.
Mike
57 Panhead
RECVEH2005 wrote: Steve, My failing is that I don't have any patience with shoddy workmanship and/or poor customer service. I guess I'd better get over it if I'm going live thru another RV purchase
Mike
I carry a roll of Eternabond with us all the time, used it on our last trailer on the seams and plan to use it in this trailer as well.
I have little patience as well for lousy customer service and shoddy work, but at this point I'm just going to take a step back and try to enjoy the trailer. I'm not going to give up all together, just take a breather for a bit, but I will keep a close eye on the roof. They win round one.
Steve
cjoseph
WV
I would get a copy of the roof material manufacturer's installation instructions. Surely, it will say remove all debris and knock off any high spots before install.
Maybe they don't want to intercede on your behalf, but they should be willing to provide installation instructions to anybody. Maybe they are available on line.
Good luck.
Chuck, Heidi, Jessica, Nicholas & Tan Puppy
2008 3/4-ton Yukon XL, Flagstaff 831BHSS
Equalizer Hitch and Prodigy
mwebber78
New England
I realize this is Alpha Systems that supplied the roofing material but Dicor also makes the majority of the roofing systems. In their instructions to the RV manufacturer it states to apply the substrate and use fastners that sit flush or slightly lower to the substrate. It also says at side wall transitions, seams, and over the screws that it is advised you apply felt seam tape.
2013 Jayco Eagle 334RBTS
Disclaimer for the daft: Don't confuse my opinion with facts.
