RV.Net Open Roads Forum: Fifth-Wheels: Sidewinder Pinbox with long box truck
 > Sidewinder Pinbox with long box truck
Paul G.
SW, MN
Posted: 03/09/12 02:37pm Link  |  Print  |  Notify Moderator
I'm trying to keep the rear of the pinbox from hitting the bed rails on the pickup. (2010 Silverado 3500HD)(2003 Cardinal - extended pinbox)
Does anyone here use the Sidewinder Pinbox with a long bed truck? It's either a Sidewinder or a shorter pinbox.
Any downside to the Sidewinder with the long box.
Any info would be appreciated.
Paul....
HamsHog
Fulltimer/ Palm Springs, CA
Posted: 03/09/12 04:26pm Link  |  Print  |  Notify Moderator
Paul....
Hey Paul,
The downside isn't the Sidewinder with a long box, but whether your frame will over flex with the extended length of the Sidewinder on the extended pin box that Cardinal installed as OEM equip. You may end up bending your frame.... Better check with Cardinal before installing..
Regards, Hamshog
2009 Silverado 2500HD EC/SB Dmax/Alli - SuperGlide 18K - Firestone Bags - 265/75R16's -
2010 Carri-Lite 36XTRM5 w/ Big Foot - Champion 4000W
2005 Harley-Davidson Road King Classic
2005 Jeep Wrangler Unlimited LJ
2007 Fleetwood Pegasus Ultralite M-180FQ
glazier
Kentucky
Posted: 03/10/12 04:49am Link  |  Print  |  Notify Moderator
Pretty much every manufacturer offers the Sidewinder now as an option. I really like this set-up, especially the way you can use a much lighter non sliding hitch. I see no problem using one with a LB truck.
I would consider calling the manufacturer just to make sure you have no problem with frame issues.
2010 Jayco Eagle Super Lite 31.5 FBHS
08 Chevy 2500HD LTZ Duramax CC/SB/4X4
Titan 52 Gallon Tank, Banks Speedbrake
Reese 18K Signature Series
Bilstein Shocks, Ride-Rite Air Springs
Butch50
Bentonville, AR
Posted: 03/09/12 04:41pm Link  |  Print  |  Notify Moderator
No problem with the Sidewinder on a LB. That is what I'm towing with on my Arctic Fox and Ford F350 LB. Arctic Fox installed my Sidewinder from the Factory so I guess it is OK to use.
Butch
2011 F350 KR 4X4 CC LB SRW
2012 Northern Lite 10 2 CDSE
2010 Can-Am 650XT Outlander Max
2012 Harley Tri Glide
Dave&Monica
Ontario
Posted: 03/09/12 05:02pm Link  |  Print  |  Notify Moderator
Can you gain more clearance of the pinbox to the truck rails by raising the pin box and then increasing the hitch height to compensate? As the pin box is angled this may be sufficient.
Dave
2010 Rockwood 8280WS
2008 F250 CC Lariat SB 6.8L V10
Pipewelder
Posted: 03/09/12 07:18pm Link  |  Print  |  Notify Moderator
Paul....
Hey Paul,
Regards, Hamshog
X2--- I would defiantly check with Cardinal as they build a heavy fiver.
mobilcastle
OH
Posted: 03/10/12 05:26am Link  |  Print  |  Notify Moderator
My Chevy 3500 2011 truck rails are also high. I went to a short pinbox to solve the problem-works fine. Are you going to have to change your hitch to use the sidewinder? Some hitch makers like B&W do not recommend their hitch be used with a wedge.
2010 Heartland 3670RL Mor/Ryde PB,dual panes,2-AC,
7000lb axles,G rated LT tires,38' high profile,
2011 Chevy 3500HD,Dually,D/A,LB,EB,4X4,
B&W Companion,GVWR-13,000
oldbiker7
Western Colorado
Posted: 03/10/12 08:48am Link  |  Print  |  Notify Moderator
This is only partially correct: B&W does not recommend using the Sidewinder on their Companion (GN) mounted hitch but it is fine with their newer Patriot hitch (and works very well).
2013 GMC 3500 Duramax CCSB 4x4, B&W Patriot hitch
2013 Arctic Fox 27-5L
2008Wildcat
PA
Posted: 03/10/12 05:38am Link  |  Print  |  Notify Moderator
A new, shorter pinbox should be half the price of a Sidewinder.....and serve the same end result.
Paul G.
SW, MN
Posted: 03/10/12 05:41am Link  |  Print  |  Notify Moderator
mobilcastle:
Just wondering where you got the short pinbox, I have been looking but no one seems to know much about replacing my extended pinbox with the short one. I've talked with Forest River, Lippert and two private RV Dealerships.
Thanks.
Paul...
