RV.Net Open Roads Forum: Tow Vehicles: Did a little PM today...
Search only in Tow Vehicles
 > Did a little PM today...
ib516
Up here!
Posted: 03/10/12 06:52pm Link  |  Print  |  Notify Moderator
Here's the list:
- Flushed power steering system with a flush chemical and refilled with semi synthetic fluid by BG Products HERE. I used the BG quick clean (purple can), ran the truck a bit, turned the wheels back and forth a lot stop to stop, then flushed and refilled with the BG red 'Power Clean' power steering fluid.
- Did a rear diff service, went from 75w90 synthetic and this diff cover:
(NOTE: That liquid under the truck is water, not oil -- from slush dripping off the chassis)
To this cover filled with 5.5 quarts of AMSOIL 75w110 gear oil:
- Then I did an oil change/chassis lube. First I added some engine flush (LINK), and idled the engine for a bit, then drained and refilled with 15w40 dino oil and a Fleetgaurd Stratopore oil filter.
- Next I changed the fuel filter and air filter. I used the Fleetgaurd Stratopore fuel filter, and the NAPA 9946 air filter with 4" pleats.
Weather was great, all work was done over at my buddies place. What a great way for a gearhead to spend a Saturday afternoon. Thanks Ron (CND Supercrew) for lending me the gear oil pump. It made the job much easier!
* This post was edited 03/10/12 07:28pm by ib516 *
2010 Cougar 322QBS 5er
2007 Dodge 3500 SRW Megacab, 4x4, 5.9L Cummins, 3.73, 48RE auto
HYPERTECH MAX ENERGY or DIABLO PREDATOR tuning
MBRP 4" Turbo back
Scangauge2 for Boost, Coolant temp, Rail press & Trans Temp
Torklift Stable Loads
coolbreeze01
Redding, Ca
Posted: 03/10/12 07:02pm Link  |  Print  |  Notify Moderator
Nice work, but does the good looking diff cover add capacity? "filled with 5.5 quarts of AMSOIL 75w110 gear oil:"
The 11.5 Rear Axle only takes 8.45 Pints stock. Overfilling can blow out axle seals I hear.
2008 Dodge 3500 With a Really Strong Tractor Motor...........
LB, SRW, 4X4, 6-Speed Auto, 3.73, Prodigy P3, Blue Ox Sway Pro........
2007 Komfort 212 on 225 75R 15E Maxxis ST Tires.........
ib516
Up here!
Posted: 03/10/12 07:06pm Link  |  Print  |  Notify Moderator
Yes it's about 2x as deep as the stock cover.
Stock, it held about 3.6L (just under 4 quarts). I have serviced it twice in stock form. This time, I bought 6 quarts, and I used 5.5 of them give or take.
Here's a shot of one I got off the web that shows the depth better (not my truck).
I like the PPE cover as it has fins on the inside too. Most are smooth on the inside and have fins just on the outside.
bmanning
Phoenix, AZ
Posted: 03/10/12 07:07pm Link  |  Print  |  Notify Moderator
Great for your truck and you obviously enjoyed yourself; would you like to borrow my Land Cruiser next Saturday and relive the joy again?
LOL
I'm basically due to drain & fill everything and you've motivated me to quit putting it off and man up.
BManning
baking in Phoenix
2008 Ford Super Duty F250 XLT, 4x4, crew cab, 6.75' bed
5.4L V8 300hp/365ft-lb, 5sp Torqshift, 4.30 AAM gears
9400lb GVW 11200lb tow
2007 Volvo XC90 AWD V8
4.4L 311hp/325ft-lb, 6sp Aisin, loaded
6100lb GVW 5000lb tow
2003silverado
Michigan
Posted: 03/10/12 07:15pm Link  |  Print  |  Notify Moderator
Looks like u had a minor spill.
Must be the weather is as nice up there as it is down here to be working outside this early in the year!
ib516
Up here!
Posted: 03/10/12 07:27pm Link  |  Print  |  Notify Moderator
Weather was great, we lost a lot of snow today. The spill was just water dripping off the truck. We caught all the oil in the drain pan.
45Ricochet
North Idaho
Posted: 03/10/12 07:44pm Link  |  Print  |  Notify Moderator
Good job IB but from my experience its really hard waxing those fins
You mention "lube" also. So you did get the front drive shaft lubed also
That little needle don't do much good if you can find the hole. Terrible design with no lube zerks IMO. Yeah old school comings out I guess.
06 Ram 3500 CC LB Laramie 4x4 Dually 5.9 Cummins Smarty Jr 48RE Jacobs brake
GVWR 12,200 RAWR 9350
06 Grand Junction 34' High profile 15500 GVWR 3200 pin Mor/ryde 5500 Onan genny Dual A/C Wet bolts
27' Hallett 502, 500HP
coolbreeze01
Redding, Ca
Posted: 03/10/12 07:45pm Link  |  Print  |  Notify Moderator
"Yes it's about 2x as deep as the stock cover."
Thanks for the pics, good looking unit.
larry barnhart
wenatchee. wa usa
Posted: 03/10/12 08:11pm Link  |  Print  |  Notify Moderator
ib516 wrote:
Here's the list:
the before picture show the differential has been hot
Do you feel it was?
chevman
chevman
2001 35 ft avalon alpenlite RK
prodigy
easyrider/reese airhitch
trailair center point suspension
JT Strong Arm Stabilizers
KSH 55 inbed fuel tank
Garmin 2720
scanguage II
TD-EOC
Induction Overhaul Kit
TST tire monitors
66chevelle
Mi
Posted: 03/11/12 04:25am Link  |  Print  |  Notify Moderator
Great job ib516 but I have a question, being that you are from Canada why don't you have your truck sprayed with Krown to stop the rust? I live in Mi and get my vehicles sprayed every year, and I have zero rust anywhere.
2006 Chevy cc dually D/A 4x4, 2008 Cardinal Fifthwheel 33TBH
