RV.Net Open Roads Forum: Class A Motorhomes: Norcold has New Recall
Open Roads Forum  >  Class A Motorhomes  >  Safety Issues & Recalls
 > Norcold has New Recall
Page of 7
RCtime
So. Calif.
Posted: 03/13/12 08:22am Link  |  Quote  |  Print  |  Notify Moderator
I disconnect my house batteries every time I put my coach in storage , or non-use for any period of time via the house battery disconnect switch. 100s of times. Plus I have one of the 1st, not THE 1ST generation of recall boxes and no problems.
Ron
2002 34HD Winnebago Journey DL, Cat. 330/freightliner
2004 Honda CRV - Garmin 1490t
Great wife & Cavalier King Charles Spaniel
TT/N
doc brown
Redondo Beach, CA,
Posted: 03/13/12 08:27am Link  |  Quote  |  Print  |  Notify Moderator
Larry Cohen wrote:
It's amazing that this company is surviving...as someone mentioned above, one catastrophe due to this POS refrigerator may put them away....I have ZERO regrets changing over to Whirlpool!!!
I had recall A-D before I tossed the Norcold.
Steve,Kathy,Josh & Morpheus the Basenji
2004 40' TSDP Country Coach Inspire DaVinci
350 Cummins, 3000 Allison
2008 Wrangler X Rubicon/Blue OX Tow Bar/Ready Brake
Ivylog
Blairsville, Ga. USA
Posted: 03/13/12 08:32am Link  |  Quote  |  Print  |  Notify Moderator
Sooboy wrote:
Ivylog wrote:
Norcold is now on revision E of this bandaid.
Would someone be able to tell me how to tell which revision is installed in my RV? Where would I look?
Thanks!
Take the outside vent off and find the black 2" square box that may be clamped to one of the tubes and the sticker on it should say which one you have.
04 Monaco Dynasty 42' quad slide
Where am I?
How I tow.
Buck62
Charleston, South Carolina
Posted: 03/13/12 08:35am Link  |  Quote  |  Print  |  Notify Moderator
I am not doing the recalls, I installed a SS-30 Small-Format Automatic-Release Fire Extinguisher in my refer back cabinet. The extinguisher is aimed at the fire box and will automatically trigger one pound of Halon into the refer compartment.
hottubkid
SCHAUMBURG,IL
Posted: 03/13/12 09:01am Link  |  Quote  |  Print  |  Notify Moderator
confused,,, Is this all norcold 1200 refers???????
hottubkid60193@yahoo.com
2004 SOUTHWIND 36E Tow 2003 CRV
wingtraveler
Alamo, Texas
Posted: 03/13/12 10:01am Link  |  Quote  |  Print  |  Notify Moderator
yes
08 Discovery 40x
08 Hyundai Sonata GL toad
08 Honda Goldwing
RayChez
Barstow, Ca. USA
Posted: 03/13/12 10:26am Link  |  Quote  |  Print  |  Notify Moderator
The last recall was the heat sensor on my coach, and I have not had any problems with it and I have my inverter turned off all the time. I have disconnected my batteries when servicing them. Knock on wood but my has been flawless.
2002 Gulf Stream Scenic Cruiser
330 HP Caterpillar
3000 Allison Transmission
Neway Freightliner chassis
2013 Honda CR-V EX
Aventa II
FMCA member
Gale Hawkins
Murray, KY
Posted: 03/13/12 01:00pm Link  |  Quote  |  Print  |  Notify Moderator
Streetlight wrote:
I guess I got lucky. I replaced my house batteries last month and my frig works fine. Could be that my coach was plugged into shore power while I changed the batteries and the frig was powered by the inverter.
I expect that saved the day for you.
Not sure why Norcold would build it that way since it is sure someone is going to have a RV with a battery shut-off switch and use it.
Jim@HiTek
Gresham, OR, USA
Posted: 03/13/12 01:31pm Link  |  Quote  |  Print  |  Notify Moderator
Wow, and then there's those of us who are planning on upgrading our RVs this fall...I've been looking at used units for months and they are almost always 2-4 door Norcolds! Darnit!
My Dometic hasn't been trouble free, but at least I don't have to worry about it burning down my RV.
Jim@HiTek
Have shop, will travel!
Visit my travel & RV repair blog site. Subscribe for emailed updates.
Fleetwood Bounder, '94
Cummins Diesel, 190HP, 36.5' with 50HP LP boost.
Black Rock Lava Park, Nevada
clydeturre
Lake Havasu City,AZ
Posted: 03/13/12 02:18pm Link  |  Quote  |  Print  |  Notify Moderator
Open the outside access door to fridge. At upper left there is a board
with 4 wires and a red led bulb. That indicates the latest fix. I just had
that recall done.
Page of 7
