RV.Net Open Roads Forum: Help pls. Lavender Oil to prevent mice in trailer
 > Help pls. Lavender Oil to prevent mice in trailer
gilldawg79
Alabama
Posted: 03/13/12 08:27pm Link  |  Print  |  Notify Moderator
CavemanCharlie wrote:
None of this stuff will ever work. The best option is to get a cat and ,most importantly, don't feed it much. My camper sets in my shed I have 3 cats and I give them one handful of cat food a day. Just enough to keep them around. If you feed a cat to much it will get fat and not hunt. A hungry cat is a good cat.
If this won't work for you then mouse traps is the next best thing. Plus, Try to plug up all the holes you can. But, if you have a real mouse problem they will just eat through a new hole. Also, remove all the good smelling food from the camper while it's in storage. Canned food, and such, is fine. But, if you have things setting around that a mouse can smell, he will find it. No matter what you do.
Do not use poisons and such. They will kill the mouse and then it will die in the wall and stink like hell.
Cats or traps is my opinion.
X2 on the cats. I have one and he is a killing machine. He gets a bowl of food every day or so. He has a tendency to eat squirrels every now and then and that is not pretty. He is a vicious hunter, but the friendliest cat I have ever been around. I don't particularly like cats, but this one is a great one. We had mice problems at our house a few years ago and after we got him they went away.
Jimmy
West Central Alabama
2012 Jayco JayFlight 26RKS w/ side bunks
2006 GMC Ext Cab 2500HD 4X4/6.0/4.10
RTR!
Ole Man Dan
Gadsden, Alabama
Posted: 03/13/12 09:28pm Link  |  Print  |  Notify Moderator
Not sure about the effectiveness of Lavender Oil, I'd plug any holes and get a cat. Put out mouse traps inside your trailer.
midnightsadie
ohio
Posted: 03/14/12 04:44am Link  |  Print  |  Notify Moderator
farmers use a product called kab clean in there 200k tractors and don,t have mice ,the spelling could be off on the product. me I use peppermint oil and kab clean no mice it boats or rv.
NHIrish
White Mountains NH
Posted: 03/14/12 06:28am Link  |  Print  |  Notify Moderator
mlts22 wrote:
X2. We see the peppermint oil and dryer sheets often. Both just make the vermin smell better and have softer coats as they gnaw through wiring.
I'd just go for mousetraps. The bucket trap is simple, effective, and can handle a bunch of mice when left over a winter in an RV.
Bingo! I was feeling cocky this winter after 3 years with no mice. Well, it sure is a lot if work taking everything out for washing, shampooing carpets etc. Back to the bucket trap ouside this fall and traps inside. Also going to do some spray foam work as I have not yet done it on this rig!
2010 Carriage Cameo 32FWS
2011 Chevrolet 3500 DMAX ECLB
B&W Companion
Diplomacy is the art of saying 'Nice doggie' until you can find a rock
rgolding
Southern Illinois
Posted: 03/14/12 06:33am Link  |  Print  |  Notify Moderator
"Also going to do some spray foam work as I have not yet done it on this rig!"
That does a lot to resolve all sorts of problems with bugs and critters. You can buy a very cheap plastic faucette supply line about 30 inches long for under $7 and use it as an extension on a can of "Great Stuff" to get in areas your arms won't reach.
fleetwood05
East Coast
Posted: 03/16/12 08:39am Link  |  Print  |  Notify Moderator
smildrum wrote:
In our situation- I agree somewhat with the above posters. Peppermint oil on cotton balls- yes- however I also placed them in plastic tubs with covers, such as margarine tubs with X slits cut in the tops. We don't use steel wool- it can rust with moisture. Use bronze wool instead. And yes use foam in addition to the wool. Lastly, we try to take a defensive action outside the camper. We have mouse traps set-up with peanut butter under the camper but the best part is they are set-up under an upside-down milk crate that has a heavy stone on it. The mice can get to the traps and get caught before they get to the camper. This is our first year trying this method and can confrim that Yes, it does work.
Please tell me where you get the best deal for bronze wool.
mastercraft1995
Salem, Or
Posted: 03/16/12 09:35am Link  |  Print  |  Notify Moderator
I use the little green pine scent tree's in out boat and haven't had a problem with mice. I usually refresh the tree's in January. I out about 12 tree's in the boat when I winterize it.
2012 Tundra, Super White, Double Cab, 4x4, TRD, 5.7L
1999 Nash 25S
