RV.Net Open Roads Forum: Do you pull your toad with kayaks on it's roof?
 > Do you pull your toad with kayaks on it's roof?
trickto322
Sioux Falls,S.D.
Posted: 03/14/12 08:22pm Link  |  Print  |  Notify Moderator
We tow a silverado with (2) 12' kayaks on a Thule rack. Not a problem, at all.
the silverback
SW Mich
Posted: 03/14/12 09:25pm Link  |  Print  |  Notify Moderator
I have pulled my Edge behind the MH with a kayak on the roof for 1000's of miles. NO PROBLEM!!!!
the silverback
nelson
Clio,Mi USA
Posted: 03/15/12 05:37am Link  |  Print  |  Notify Moderator
We have two set on top kayaks we put on top of out toad for four years now without any problem.
2002 Damon Challenger 348 Ford V10
Blue Ox Auto Stop and Aventa II Tow Bar
2001 Ford Sport Trac with Remco Driveshaft Disconnect
BoarderExman
Palmyra, PA , USA
Posted: 03/14/12 09:31pm Link  |  Print  |  Notify Moderator
I tow our Edge with kayaks and or a kayak/bike combo on our roof with thule racks and haven't had any problems. I also use a hitch mounted rack for additional bikes.
I am currently setting up my utility trailer as a kayak carrier. I made a rack out of 2x4s which bolts to my side kit. It can hold up to 4 kayaks. I have yet to try it out, but hope to use it when we want to go somewhere that won't require the use of a toad.
This set-up will be much more susceptible to any wind issues caused by the motorhome due to the light weight of the utility trailer.
When I have a go at it I'll report back with the results.
By the way I have never used bow and stern tie downs in all my years and thousands of miles of carrying kayaks, I realize they probably are a good idea though.
Mark,
Wife and 2 kids(daughters)
2002 Winnebago Adventurer 32V
Greyghost
On The Road To Somewhere
Posted: 03/14/12 10:12pm Link  |  Print  |  Notify Moderator
We've got about 30K miles towing with 2 kayaks on the roof of our CRV. Of course we use Thule Racks and have never had a problem. Go with Thule Hull-a-ports or an equivalent, ours are about 13 years old and never a problem.
Pat & Roger Fisher
2004 Mountain Aire 3501
2007 Honda CRV EX-L 4WD,
Jewel and Clifford Bouvier Des Flandres
Gappy
NE Indiana
Posted: 03/15/12 04:55am Link  |  Print  |  Notify Moderator
I think I should refer Yakima to this thread.
Thanks for all of the input!
Tom
2013 Silverado 2500 Duramax Crew LTZ Z71 4x4
2013 Winnebago ONE 32BH
jswickard
Summerfield, FL
Posted: 03/15/12 05:53am Link  |  Print  |  Notify Moderator
We did about 10K miles last year towing a Honda Pilot, using the Honda rails, Yakama cross bars and homemade longitudinal supports (made out of PVC pipe). Two 12 ft sit-on-top kayaks are held down with two individual straps on each yak, and the straps are attached to the Yakama cross bars. Two straps on each yak is in consideration that if one should loosen, the second serves as a back-up. Also, the longitudinal supports have plugs which go up into a couple scupper holes to help prevent any shift rearward. Probably have done another 20K with the same set-up behind our previous moho. No problems in all those miles.
Jim and Rosalie Swickard
2011 Newmar Ventana 3433
2004 Honda Pilot
Gappy
NE Indiana
Posted: 03/15/12 06:23am Link  |  Print  |  Notify Moderator
Have any of you been specifically doing what I wanted to do on the same vehicle that Yakima shot down?
This was going to be my set up....vehicle is '07 4 dr wrangler, I already have the rain gutter towers and round tube rails. I was going to buy yakima's "Hullraiser Areo" or "Bowdown", both specifically made to carry kayaks on their side. We have two 16 ft double (2 seat) kayaks (4 person family) which is what I wanted to carry understanding that there may only be enough room on the roof for one of these kayaks because they are quite large.
Anybody carrying double (2 seat)kayaks on top of a 4 dr wrangler?
newlee
Ca USA
Posted: 03/15/12 07:47am Link  |  Print  |  Notify Moderator
I have been doing it for years witg no problem.
2 kayaks on a Jeep Wrangler also on a Jeep Grand Cherokee on a Ford Ranger and a Ford Explorer Sport Trac
Plus bikes on the back of the TOAD.
Dan & Pat Newhall
Central California
2003 Newmar Kountry Star DP 3353
2001 Jeep Grand Cherokee Toad
1995 Ford Ranger STX 4X4 Toad
1995 Jeep Wrangler Toad (KISA RCK}
dieharder
Ottawa, ON
Posted: 03/15/12 08:46am Link  |  Print  |  Notify Moderator
I'm going to say that this should all depend on how far the kayak/canoe/whatever extends to/beyond the front of the towed vehicle.
When the RV is moving down the road, a vaccuum is created behind it, pulling the air that passes over and below it toward the center of the back of the RV where the 'void' is. Once it gets there, it just circulates around because of the other air that follows it, creating the cyclone effect. You can see it often in winter with pickup trucks. So, if the tip of the canoe/kayak breaches into this area, you could have an issue. However, I doubt that there are any that reach that far forward, since I assume it would have to be pretty far beyond the front of the toad.
1999 Itasca Sunrise
