RV.Net Open Roads Forum: Class A Motorhomes: Securing stuff in Residential Refer
 > Securing stuff in Residential Refer
SMC
Box Elder, SD
Posted: 03/14/12 03:06pm Link  |  Print  |  Notify Moderator
In our previous RV's, we've been able to secure the stuff in the refer with use of the tension bars. Even with the side by side residential refer in the Country Coach, we could use the bars and keep everything on the shelves.
Now, with the Maytag residential refer, the configuration is different. (side by side refer doors and the freeze is down below). How do you keep things from sliding all over? I can put the anti-slip stuff on the shelves, but that still won't keep things from tipping over. Baskets would work, but they sure cut down on the storage space.
For those of you who have this style of refer, what is your trick?
SMC
Home is Where We Park It!
2012 Newmar Dutch Star 4346
2011 GMC Canyon
steveownby
Cosby, TN
Posted: 03/14/12 04:19pm Link  |  Print  |  Notify Moderator
I found some tension rods at Walmart that are long enought To do the job.
Steve Ownby
2003 Monaco Signature
Full-time since 2007
Blaster Man
Posted: 03/14/12 05:56pm Link  |  Print  |  Notify Moderator
Put items in small containers, then put them in the refrig. Or, keep the refrig really really full.
rr2254545
Minnesota/New Mexico
Posted: 03/14/12 06:51pm Link  |  Print  |  Notify Moderator
We just pack the items in, first few miles we dumped a full gallon of milk on the floor, now I tie the door shut. The top hasp that was supposed to hold the top doors shut broke at the same time. We have a Maytag
2012 Winnebago Journey 36M Cummins 360
131 Campgrounds since we retired in July 2009
pusherpilot
Wherever we are.
Posted: 03/14/12 08:05pm Link  |  Print  |  Notify Moderator
We got the curtain rods at WalMart and have had no problems in 4000 mi. We secure the doors while moving but otherwise no special treatment.
Ron
SMC
Box Elder, SD
Posted: 03/14/12 10:35pm Link  |  Print  |  Notify Moderator
I went to Target this evening and picked up some of the shelf anti-slip stuff and 2 tension rods that are longer so that should do the trick. Thanks for your ideas.
chrisnjackie
Land O Lakes, Florida
Posted: 03/14/12 10:59pm Link  |  Print  |  Notify Moderator
First turn I made when I first got my RV resulted in half the stuff coming out of refrigerator.
I thought the lock button on the control panel was to lock the doors. Who knew it was to lock in the temperature selections. Velco strap sold at any big box home center works just fine in route and easy to put on and take off.
SMC
Box Elder, SD
Posted: 03/14/12 11:07pm Link  |  Print  |  Notify Moderator
At least the door locks worked and the eggs were in a drawer. Hopefully I have the problem solved.
Tinstar
McKinney, TX
Posted: 03/15/12 12:52am Link  |  Print  |  Notify Moderator
2X's on curtain rods.
Never pass up a chance to go somewhere
