RV.Net Open Roads Forum: Towing: Hensley Arrow advice
Search only in Towing
Open Roads Forum  >  Towing
 > Hensley Arrow advice
Procrastinator
Southern Illinois
Posted: 03/15/12 03:55pm Link  |  Print  |  Notify Moderator
After hours and hours of research I decided I was going to buy a projected pivot tow system. After months of searching for a deal, I purchased a used HA for $200.00. It is still intact, but has seen better days. Some paint peeling, surface rust, needs bearing(s), and a few small parts ( cleavis pin/ ubolt). I know these hitches are stout and I am mechanicallly inclined. I read various posts last night about other campers rebuilding/painting theirs so I know I can do it.
I would like to ask a favor from any HA owner though. Could you pm or email me. I would also like to speak to a human on the telephone and try to get anymore advice before I start this task.
If there is anyone in the St. Louis MO area that has one and is willing to let me come look at yours, I would like to see yours in person just to get a better understanding maybe some photos.
Thanks for any help
Procrastinator
2003 Ford Excursion 7.3 diesel
1984 Avion 34W triple axle no slide
Husband, Wife, Son, Daughter, Olde English Bulldog and a Great Dane
BarneyS
S.E. Lower Michigan
Posted: 03/15/12 04:25pm Link  |  Print  |  Notify Moderator
The Hensley hitch is very easy to rebuild. I did mine last winter and posted the process, complete with pictures, here. I am sure that it will give you some help.
Barney
Hensley "Arrow" 1400# hitch
2002 Ford F250 Super Duty, 7.3L PSD
Visit our website here
Slowmover
Corpus Christi, Texas
Posted: 03/20/12 08:09pm Link  |  Print  |  Notify Moderator
Past Barney's rebuild, the best overall thread on the web on the Arrow is The Ultimate HAHA Users Guide
What you've read and the two links will cover all of it.
The AIR forum has a few other AVION owners and -- I think at least one of them with the stub axle type as you have -- also with a VPP hitch.
Getting the trailer "centered" behind the truck was the hardest part for me (as adjustments side-to-side were never mirror images on, now, two trailers).
1990 35' SILVER STREAK Sterling, 9k GVWR
2004 DODGE 305/555 ISB, QC SRW LB NV-5600, 9k GVWR
Hensley Arrow; 15-cpm solo, 25-cpm towing
BurbMan
Louisville, KY
Posted: 03/20/12 08:11pm Link  |  Print  |  Notify Moderator
I am a 10-yr HA owner in Louisville. Call me (Don) anytime 631-404-0131 I can send pics if you need. I just had mine off for a spring refresh and is back in service again. Let me know what you need help with.
jerem0621
Sequatchie, TN
Posted: 03/20/12 08:18pm Link  |  Print  |  Notify Moderator
man, how come I can never seem to find a 200$ HAHA. I would change if I could find one that cheap.
I do have a question... if a used HaHa doesn't have the correct wd bars does the HaHa use standard reese round bars? They look a lot like standard reese dual cam bars.
op great buy! and good luck!
ps. thanks for the above links.
jeremiah
* This post was edited 03/20/12 08:51pm by jerem0621 *
TT: 1995 Layton 2910
Tow Vehicle: 1999 F-350, v10, 2wd, Crew Cab, Dually
Hitch: Draw-Tite Trunnion WD Hitch
Sway Control: Valley dual friction sway control
Brake Control: Tekonsha Voyager
"It's Kind of Fun To Do The Impossible"
~Walt Disney~
Procrastinator
Southern Illinois
Posted: 03/20/12 09:17pm Link  |  Print  |  Notify Moderator
Thanks for all the information. I had already read Barneys, AIR, and one other rebuild posts. Very helpful but I always want more infomation. The complete guide to HaHa is going to take some time but I think it will do the trick nicely.
As for my rebuild...taking it apart was really easy. Very simple and sturdy construction. Removingthe powdercoating no so easy. My sand blast cabinet would not touch it. I ended up having a professional strip the main units. FYI permetex gasket remover will soften and remove most powdercoatings. I have most of the stuts painted and waiting for clear coats. The main units are just starting their primer coats. I spent about $400 for parts and improvements Monday. So in about two weeks I will have it all done pretty and working.
Thanks again procrastinator
Procrastinator
Southern Illinois
Posted: 03/27/12 02:02pm Link  |  Print  |  Notify Moderator
Ok, I got all my parts sandblasted, painted, and now I am putting it all back together but I have a problem.
I know the bearing/grease seals are tight, but so far I have bent 3 out of the 4 seals. not even close to going in. What is wrong? My seals are about 35000th's bigger than the bore they are going into. I know you set them tap with wood flat no dice. Borrowed a buddy's grease seal install tool. Same thing. Shoved two in the freezer. Same thing. Called Hensley they thought they were just standard seals and he did not know a party number off hand.
I found the grease seals from the links online here. Here is what I am using:
National 473336
goducks10
Keizer OR
Posted: 03/27/12 04:40pm Link  |  Print  |  Notify Moderator
Same number I had. I used Timken but the number on the package is the same. I didn't have any trouble getting them in. I set them in the opening slightly at an angle, then tapped lightly on the higher side with a slight downward/sideways tap. Once I got the seal started I just tapped it down in a circuler motion till it was set flush. I was wondering if I was going to have trouble also since I had read a few reports of people having probs.
Procrastinator
Southern Illinois
Posted: 03/27/12 06:32pm Link  |  Print  |  Notify Moderator
Well, I got it figured out. I got a set of Federal Mogul/ MOOG grease seals. The DO NOT fit. I went to local trailer lot and picked up two (all they had) and they are a just a little smaller in diameter, do not have a "rolled" end, and the tip is tapered to get them started. So... basically, I blew 22 bucks on the Federal Mogul/ MOOG ones. Going to pick up another set tomorrow and my Hensley will be rebuilt.
Next, moving propane tanks and the intallation on the trailer.
* This post was edited 03/28/12 09:09am by Procrastinator *
Ron3rd
Upland, CA USA
Posted: 03/27/12 08:29pm Link  |  Print  |  Notify Moderator
Procrastinator wrote:
Well, I got it figured out. I got a set of Federal Mogol grease seals. The DO NOT fit. I went to local trailer lot and picked up two (all they had) and they are a just a little smaller in diameter, do not have a "rolled" end, and the tip is tapered to get them started. So... basically, I blew 22 bucks on the Federal Mogol ones. Going to pick up another set tomorrow and my Hensley will be rebuilt.
Keep us posted on your progress. Sounds like you've got a very nice project going.
2004 Aljo 250LT
Eaz-Lift WD Hitch
Single Friction Sway Control
Prodigy Brake Controller
Honda EU2000
