RV.Net Open Roads Forum: Travel Trailers: No life from the furnace
 > No life from the furnace
justaboutretired
Florence, NJ
Posted: 03/16/12 07:57am Link  |  Print  |  Notify Moderator
I would take the outside cover off the heater and check inside. There maybe an on / off switch at the heater simular to the one one on your hot water heater. If nothing else, call the dealer you bought the rig at asn ask them. 2012 should be under warrenty I would think.
Bill & Diane
3 Boys, 1 dog
2002 Excursion Limited\w 7.3 PSD
2003 Citation 33M TT
mastercraft1995
Salem, Or
Posted: 03/16/12 09:39am Link  |  Print  |  Notify Moderator
Take it to the dealer.
If nothing comes on like the fan or the ticking my guess would be something electrical like the mother board or the mother board not plugged in.
2012 Tundra, Super White, Double Cab, 4x4, TRD, 5.7L
1999 Nash 25S
mastercraft1995
Salem, Or
fuse?
CavemanCharlie
Storden,MN
Posted: 03/16/12 10:58am Link  |  Print  |  Notify Moderator
Have you ever used the furnace before? Look through the manuals that came with the trailer. There is probley one for the furnace in there. It may have information that can help you. Or, maybe, if your lucky, even a number you can call.
ddepr1217
New Jersey
Posted: 03/16/12 01:27pm Link  |  Print  |  Notify Moderator
Thanks for everyone's replies. I have pretty much exhausted every suggestion and finally called the dealer. They too went through every possible solution that has been presented here. So its going in next weekend and they are going to take a look. Popular opinion seems to be that maybe the thermostat itself has malfunctioned. If given the option to repair or replace, any suggestions about maybe getting a better thermostat?
2011 Chevy Silverado 5.3 V8 3.42
2012 Prime Time Tracer 245bhs Touring Edition
robbie69
wauconda, il usa
Posted: 03/16/12 07:28pm Link  |  Print  |  Notify Moderator
replace it with a hunter-do a search here and you get the needed info
try this link
* This post was edited 03/16/12 07:40pm by robbie69 *
2004 silverado 2500HD crew cab 4x4 long bed 8.1L gas hog
2006 skyline nomad 3260 platium edition, prodigy, reese dual cam
1 very part time camping son and 3 full time camping, 4 legged fur balls
1 SU (spousal unit) who loves rv'in as much or more than me
ddepr1217
New Jersey
Posted: 03/17/12 01:50pm Link  |  Print  |  Notify Moderator
Funny thing just happened. I was just outside showing the TT to a family member and I glanced over at the thermostat and noticed that the needle that indicates the room temp had moved over considerably. Previously, it was all the way to the left indicating <50 degrees. The lever on top of the thermostat (that sets the desired temp from cooler to warmer) was in the warmest position. So I went out and turned the propane on and the heat came on! Can anyone explain this?
harleyfire18
Woodstock, IL
Posted: 03/17/12 07:14pm Link  |  Print  |  Notify Moderator
Maybe something was "stuck" or froze in the thermostat and after it warmed up a little and moved on its own that freed it? Very wierd. I would put a better stat in like a digital one that tells you the actual temp and what you have it set for. But hey it works now so I would probably also just use it the way it is and see if you have any other issues. My dealer told me to just make a list and bring the trailer back when I get my list of repair needs built up (ie warrenty stuff)
73 Matt KC9SVJ
06 F250 Super Duty Lariat with a 6.0 Power Stroke Diesel pulling a 2012 Kodiak 284BHSL
ltdan
Rossville, GA
Posted: 03/17/12 07:36pm Link  |  Print  |  Notify Moderator
Is the battery charged or the trailer plugged in?
Dan
