BraamRW
Raleigh, NC
I purchased a 2012 Redwood 36RL Oct 1, 2012 and have been living it full time ever since. Pulled it approximately 9000 miles plus over back roads and interstate. The only problems I have had is the the thermostate for the electric part of the hot water heater and the plastic flip seal on the left door of the refrigerator. Other than those 2 minor items this is the most enjoyable full featured fifth wheel I have owned. My choice was between the Carriage Cameo and the Redwood. Choose this one and never looked back. I am extremely pleased the quality, fit and finish of this unit. Including the frame, hydrolics, and axels. I did swap my 17.5" rims and tires from the old unit for the 16" on the Redwood.
kfdray
Montana
Thank you for the hopeful note. My action item list has reached 9 items...
Dave & Ginny
peoria, IL
I just toured the factory yesterday and although I was convinced before the tour...WOW! I got to slowly walk by each build station and I asked many..many questions. They really build a great unit. One of the employees said in the parking lot that he's worked at many of the Rv plants and this is the only one that has stressed quality and not quantity. They only make 6 a day.
sub floor is plywood and all the wood inside of it is real cherry and plastic.
kfdray
Montana
Did you ask if therre are issues with hauling the rig with a full water tank or were there any other interesting points about construction/durability you would care to share?
Dave & Ginny
peoria, IL
kfdray wrote: Did you ask if therre are issues with hauling the rig with a full water tank or were there any other interesting points about construction/durability you would care to share?
The only thing that I would worry about is that the 104 gal. fresh water tank in in the basement so if that was full it would add a lot of weight to your pin weight. If you have a truck that can handle the extra weight ...then you'd be fine. I think some of that weight will still be carried by the trailer axles but I don't know how much.
Dave & Ginny
peoria, IL
Duck wrote: Just looked at the Redwoods today and their quality is not as good as the Carriage. Just do not like all of the running gear being made by Lippert.
Don
There only a couple of RV's out there without the Lippert running gear. I toured the factory and looked real close at the frames because of all I've read on this forum about them. They said that Lippert gave them a great proposal so they went with them. Otherwize they were going to build their own. They said that so far they haven't had a single issue with the frames.
kfdray
Montana
Dave & Ginny wrote: Duck wrote: Just looked at the Redwoods today and their quality is not as good as the Carriage. Just do not like all of the running gear being made by Lippert.
Don
Excel uses Mor-Ryde suspension with 7000 or 8000 lb. axles depending on the size of the rig. Is the Mor-Ryde system that much better than what Lippert uses?
KR2011
They are the same design redwwood and lippert uses the trail air equaflex suspension system
edited 03/30/12 09:42am by KR2011 *
[b]2011 F350 DRW 4 corner air ride
2006 Montana 3650RK
2012 Redwood 36FL on order
Note: Due to invalid formatting, all formatting has been ignored.
Duck
Miami Lakes, Fl
Don
I know that it is hard to get away from a Lippert frame but it is easy to find Dexter wheels, brakes, and bearings and MorRyde pin box.
Don
08-FORD F350 PSD
13 Bighorn 3055RL
Dustytuu
Somewhere in the USA
The CEO that was REMOVED is who did the damage. he was let go. He now works for Thor.
Lots of rumors going around. Some untrue and some half truths and some true. Very few are true.
edited 03/24/12 11:34am by Dustytuu *
