RV.Net Open Roads Forum: Technology Corner: Printer choice for rv
 > Printer choice for rv
turbopilot51
Ridgefield, WA
Posted: 03/18/12 12:56pm Link  |  Print  |  Notify Moderator
Looking for a printer to use in our fiver while traveling. We need something small but also wireless and Apple AirPrint compatible. Any suggestions?
donn0128
Pronounced Ore-gun
Posted: 03/18/12 01:05pm Link  |  Print  |  Notify Moderator
Couple of the new HP models should fit your need. I just got a HP7510 and it has more bells and whistles than I can figure out.
Donn,Lorri,Max (The Rescued Lab)
Resident Know It All
Executive
Posted: 03/18/12 01:10pm Link  |  Print  |  Notify Moderator
We've used the HP4100 for years. When shopping, make sure you check out the cost of printer INK cartridges. They can cost more than the machine. We like the 4100 because it's a printer, color/black, copy machine and scanner all in one. Easy to use and the ink is cheap.....Dennis
Dennis and Debi
Chevy HHR W/ ReadyBrute
Fourth Year Full Timing Click here to view our travel blog
Kiwi_too
Western, WA
Posted: 03/18/12 03:41pm Link  |  Print  |  Notify Moderator
Go HP and wireless if you have a wireless router.
May God bless your travels
Me, The Wonderful Wife
and two Spastic Border Collies
U.S. Army Retired
2004 Coachmen Aurora, 3480DS
2007 Saturn Outlook, FROG
rockylarson
Jersey Shore
Posted: 03/19/12 04:42am Link  |  Print  |  Notify Moderator
We have a HP 3310. Works wireless via wifi or Bluetooth. We selected it because all of the functions are viewable and accessible from the front. It resides in an upper cabinet at eye level. Be sure to take access into consideration.
2004 Allegro 30DA, Workhorse 8.1, Banks, 2003 CRV, Blue Ox Aladdin, Brake Buddy Advantage Select, 300watts solar, 7 Optima group 31 AGM's, 2000watt Ames PSW inverter.
phillyg
Front Royal, VA
Posted: 03/19/12 08:04am Link  |  Print  |  Notify Moderator
I just went through this drill because I wanted a small printer for the FW. I couldn't find anything small in the so called "portable" category that fit my needs that was also a copier/fax machine. I ended up buying an HP Envy 110 which has a fairly large footprint, but is only 3-4" tall, and the paper tray accesses through the front. It fits nicely in a cabinet where a DVD or VHS player would go. I bought it at Staples on a special for only $180, much cheaper than the serious portables I could find. Don't know about the Apple Airprint compatibility issue.
2002 Keystone Cougar 286, 8,400lbs loaded, pulled with a 2004 F150 Supercrew, 5.4, 3.73 gears. Retired and enjoying life
