BarneyS
S.E. Lower Michigan
Please take a minute before posting to consider what forum you are posting in. This forum is for modififications and upgrade posts. As it states in the sticky forum guideline at the top "Please post all repair and maintenance threads in the Tech Issues Forum and only modifications and upgrades in the DIY forum
Thank you.
Barney
Hensley "Arrow" 1400# hitch
2002 Ford F250 Super Duty, 7.3L PSD
Visit our website here
BillyW
North ID
Profdant139's post about adding fore and aft stabilizers isn't classified as an "upgrade or modification"? I don't understand how it classifies as a "repair or maintenance".
'97 F150 4X4
'04 Pioneer 18T6
Benny&Lori
Whitesboro NY
BillyW wrote: Profdant139's post about adding fore and aft stabilizers isn't classified as an "upgrade or modification"? I don't understand how it classifies as a "repair or maintenance".
Agree...
Benny and Lori
Sara, Matthew, Ashley and Christopher
Niko the camping dog!
2006 SALEM 312BHBS
2006 Dodge Ram 2500 Quad Cab
profdant139
I'm cool with wherever the moderator wants to put stuff -- I check both forums anyway!!
Our trips -- pix and text
About our trailer
ExRocketScientist
Laurel, MD
When in doubt, contact the moderator ahead of time and ask. Has worked well for me.
ERS
LAdams
Northern Illinois
I looked at profdant139's post (although this was not actually mentioned by Barney) and what Barney is saying is that the DIY Forum is for showing your modifications and improvements...
prof's post (and others that were moved) is asking a question regarding how to eliminate forward/aft movement and not actually showing the installation of said items... Had his post actually shown the installation of such items as an improvement, it would have stayed in DIY, but because he was asking a technical question, it was moved to Tech Issues... Hope my explanation clears things up...
When Barney and I created this forum, our vision was a forum showing actual modifications and improvements (with many photos), not just asking technical questions about them as that forum already existed... That was the spirit in which this forum was created...
Les
2000 Ford F-250SD, XLT, 4X4 Off Road, SuperCab
w/ 6.8L (415 C.I.) V-10/3:73LS/4R100
Banks Power Pack w/Trans Command & OttoMind
Sold Trailer - not RV'ing at this point in time
HUNTER THERMOSTAT INSTALL
HOME MADE WHEEL CHOCKS
profdant139
Les and Barney -- so just to be clear, if I want to ask HOW to modify or DIY, I would post on the tech issues -- but if I have actually DONE the modification, I post here, right? A subtle distinction, but I can certainly abide by that, if I am correctly interpreting the guidelines.
BarneyS
S.E. Lower Michigan
profdant139 wrote: Les and Barney -- so just to be clear, if I want to ask HOW to modify or DIY, I would post on the tech issues -- but if I have actually DONE the modification, I post here, right? A subtle distinction, but I can certainly abide by that, if I am correctly interpreting the guidelines.
Yep, that is pretty much how we figure it. We didn't want to take business away from the Tech Issues forum and still wanted to give the members a way to show some of the good mods and improvements they have made. Yes, a very subtle distinction and one that we discussed prior to starting this forum.
Barney
ChetsJug
Los Angeles
BarneyS wrote: ..."Please post all repair and maintenance threads in the Tech Issues Forum
Thank you.
Barney
Maybe they could change the name from Tech Issues to Repair and Maintenance threads. Also add "DIY" in front?
I myself do not consider myself a "Tech" plus what I'd like to add is not that technical. I almost posted here because I have a "DIY" thing and I clearly saw "DIY" in the name of THIS forum. Tech sounds like I'm opening up the stereo and soldering in it :/
Folks would gravitate to the repair section if it was so named.
Okay, so I have a repair idea for outside skin repair. It says "electrical and mechanical" on Tech Repair. Where can I post a "Cosmetic Repair" idea??
g'day
1976 Dodge Harvest Class A 440/727
1977 Dodge Harvest Class C 440/727
1961 Lil Loafer (by Aristocrat)
1954 Jones Way van; fiberglass
1966 Regatta outboard 950 Merc
BarneyS
S.E. Lower Michigan
ChetsJug wrote: Snip...
 g'day
It should be posted in the Tech Issues forum.
Barney
