RV.Net Open Roads Forum: Travel Trailers: Inspecting trailer brakes
 > Inspecting trailer brakes
harper223
West Texas
Posted: 03/19/12 11:02am Link  |  Print  |  Notify Moderator
What should I look for when I'm doing a routine brake inspection on the TT. Its an 09 Eagle Superlight and the brakes to my knowledge have never had this done. All I knew to do was to jack the trailer up and spin the wheels in their normal travel direction and if they were stubborn to move, they would need to be adjusted. There has to be more to it than this. Visual inspection? What should I look for? Any help is really appreciated. Remember, I'm not having brake issues, I just want to learn about the brakes and what to look for during routine maint.
Thanks
"Whatever is good to know, is difficult to to learn."
Phils
Paradise, CA
Posted: 03/19/12 11:14am Link  |  Print  |  Notify Moderator
I think it unlikely you'd find them "stubborn to move". Trailer brakes rarely have self-adjusters and even if they did, they would have to be malfunctioning to cause the wheels to be hard to turn.
Likely you'll find them easy to turn because they need adjusting. I won't detail adjustment instructions since they are easy enough to find.
The best inspection is to remove the wheels, remove the hubs, clean and regrease the bearings, replace the seals, adjust the brakes, reinstall the wheels. Also the wires and magnets need to be inspected during this work.
On an '09, I'd simply readjust the brakes but others may disagree.
Phil
'03 F250 7.3 deezle and '01 Komfort 27FS
Off the grid and outta sight at home
Go camping to have neighbors and amenities
ScottG
Bothell Wa.
Posted: 03/19/12 12:05pm Link  |  Print  |  Notify Moderator
Phil
I agree with all this especially the last line. If the bearings work smoothly and there's meat on the brakes, your good to go.
Scott, Grace and Wesly
H0NDA eu2000i
fnswhitfield
Oregon
Posted: 03/19/12 12:12pm Link  |  Print  |  Notify Moderator
I agree with Phil. If there's a very slight drag and a little rubbing noise the adjustment is OK. If the wheel spins freely with no noises, you likely need to adjust the brakes. Brake inspection, adjustment, and wheel bearing servicing kind of go hand-in-hand. It's not hard if you're a DIY'er. You can adjust the brakes without inspecting the shoes. I believe that's true for most of the electric brake pucks as well.
Fred
BarneyS
S.E. Lower Michigan
Posted: 03/19/12 12:52pm Link  |  Print  |  Notify Moderator
Take a look at this post. It will tell you how to check and maintain your brakes and your bearings. It is complete with helpful pictures.
Barney
Hensley "Arrow" 1400# hitch
2002 Ford F250 Super Duty, 7.3L PSD
Visit our website here
Chuck&Gail
In the Colorado Mountains
Posted: 03/19/12 04:53pm Link  |  Print  |  Notify Moderator
Ours is a dual axle. I pull one hub a year, check linings, regrease bearings, and reassemble. Works for me. We tow about 8000 miles a year.
Chuck
Wonderful Wife
Australian Shepherd
2010 Ford Expedition TV
