RV.Net Open Roads Forum: fiberglass house exterior: best remover of black streaks?
 > fiberglass house exterior: best remover of black streaks?
owomp
46350
Posted: 03/23/12 12:01am Link  |  Print  |  Notify Moderator
I'm going to have to try some of these.I have a black streak from the water heater not being adjusted properly,i have tried several things and bought some stuff in a spray bottle called black streak remover,wouldn't even touch it.
jorn
Twin Cities
Posted: 03/23/12 07:48am Link  |  Print  |  Notify Moderator
Just this week, I used a spray solution of Simple Green and the black streaks came off with almost no effort.
2001 Coachmen Leprechaun 314SS (Acquired in July 2008)
Replant
Someplace
Posted: 03/30/12 09:33am Link  |  Print  |  Notify Moderator
CamperKirk wrote:
Mine has a real good wax on it once a season and the streaks just wash off when I wash the motorhome.
I am interested in those gutter guards. Do they work good and easy to install??
If you mean these Yes, they work good and are simple to install. Just remove the screw and metal end cap, insert the back of the spout behind the gutter and replace the end cap and screw. Also apply ProFlex RV wherever needed.
CamperKirk
Bay Village
Posted: 03/26/12 12:57pm Link  |  Print  |  Notify Moderator
pnichols
Santa Cruz Mountains
Posted: 03/31/12 01:21pm Link  |  Print  |  Notify Moderator
Have you tried rubbing alcohol? Works great for us ... harmless, fast, available everywhere, and super cheap!
Phil, 2005 E450 Itasca 324V Spirit
Coach-man
Posted: 03/30/12 02:19pm Link  |  Print  |  Notify Moderator
If I remember correctly there was a similar post a while back on the class A forum. I can not remember the product but it was relatively in expensive and available at Walmart! Go to the Class A forum and search for "Black streaks".
Replant
Someplace
Posted: 03/31/12 02:56pm Link  |  Print  |  Notify Moderator
If WalMart doesn't have these gutter extensions you can get them from just about any RV supplier or Amazon. They come in a set of 4 for less than $10 and they just clip on and maybe fall off .
Replant
Someplace
Posted: 03/31/12 02:59pm Link  |  Print  |  Notify Moderator
But don't use laquer thinner - it seems to remove the gel coat.,Been there, done it.
