RV.Net Open Roads Forum: Is this TT too heavy for this SUV?
Search only in Tow Vehicles
 > Is this TT too heavy for this SUV?
retired-tech
flint mi
Posted: 03/21/12 05:04pm Link  |  Print  |  Notify Moderator
As a former Nissan tech i would not pull with one. the axles, trans, and cooling system have enough trouble without the extra weight. I replaced a lot of the related parts compared to the number of them we sold. Armada is not a true 1/2 ton vehicle comparatively. they use lighter drivetrains and shorter wheelbases. a real 1/2 ton truck will tow a lot better than those and probably get better fuel economy. it will also handle the weight much better. and it will live a long life.
2000 K3500 CCLB DRW 6.5 TURBO
2009 Cougar 320 SRX
2007 atlas 24 auto hauler
1987 GMC origional low miles
Terryallan
Foothills NC
Posted: 03/21/12 05:40pm Link  |  Print  |  Notify Moderator
I also believe you will need more TV. IF you need a SUV TV. A used Excursion, would be your best choice, or at the very least a 2500 series Burban
Terry & Shay
Coachman Apex 288BH.
04 F150, 5.4, Lariat SuperCab
Lazy Campers
MitchF150
Washington, the State
Posted: 03/21/12 06:10pm Link  |  Print  |  Notify Moderator
I wouldn't do it with the specs you listed.
Mitch
*Anything I post is for entertainment purposes only and what usually works for me.. Your Mileage May Vary..
Charltons
Battle Ground, WA
Posted: 03/21/12 05:41pm Link  |  Print  |  Notify Moderator
You should Be looking in the new 1/2 ton range at a minimum. If i were you though I would be looking at a3/4 ton as it will tow much easier.
2012 Dodge Ram 2500 Crew Cab 4X4 TCD
2012 Keystone Sprinter 311BHS
bikendan
Napa, Cal.
Posted: 03/21/12 05:43pm Link  |  Print  |  Notify Moderator
eric james wrote:
According to the numbers you provided, you'll be over your Armada's tongue weight capacity (900) before adding any gear to your Cougar (950).
Typically you'd want to shop around 6200 dry max for your 9000lb towing capacity. That will keep the tongue weight down too thus keeping you from exceeding your payload.
That Cougar has a very heavy tongue weight!
x2!! too much tongue weight for the Armada. you're already over with the base version of that trailer.
and are you sure you mean the Explorer and not the Excursion?
the current Explorer has a tow max of only 5000lbs.!
Dan- Firefighter, Shawn- Musician/Entrepreneur, Zoe- Faithful Golden Retriever(RIP), 2007 Chevrolet Avalanche LS, 2007 Rockwood Roo 23SS w/Equalizer and Prodigy, and 5 Mtn. bikes and 2 Road bikes
halibutman214
Oregon
Posted: 03/21/12 05:46pm Link  |  Print  |  Notify Moderator
There's a search mechanism on here that's fairly simple to use. You will find weeks of reading on this issue. WHY is it here again!
2008 Dodge Ram 6.7 Laramie SRW SB
2012 Keystone Passport 26BHWE
2009 Lance 830 with Tent foldout
20' North River Seahawk Boat
2005 Honda VTX1300
PopsRacer
Okc, Ok
Posted: 03/21/12 07:38pm Link  |  Print  |  Notify Moderator
Don't do it.. Get a 3/4-ton or 1-ton for that TT
2005 6" Lifted Nissan Armada LE (Offroad Beast)
2007 Jayco Jay Flight 29BHS
__________________________
PopsRacer
Okc, Ok
Posted: 03/21/12 07:43pm Link  |  Print  |  Notify Moderator
Interesting... Over 105k miles w/ quite a bit of towing on big offroad tires, lots of "Jeep Trail" offroading and have had nothing of the sort.. Quite a few other owners can say the same.. Pinion seals do leave some to be desired for more offroad use though...
ScottG
Bothell Wa.
Posted: 03/21/12 09:04pm Link  |  Print  |  Notify Moderator
Deleted
* This post was edited 03/21/12 09:10pm by ScottG *
Scott, Grace and Wesly
H0NDA eu2000i
patinlouisiana
Baton Rouge, La
Posted: 03/21/12 09:19pm Link  |  Print  |  Notify Moderator
I would think it is here again because someone wanted to ask the opinion of other campers!
Why look through old stuff when there are lots of members willing to offer up fresh comments!
I never get lost! Someone always tells me where to go!
2012 Prime time Tracer 230FBS Touring Edition
2010 Toyota Sequoia Limited 4X2
