down home
south
Wife is busy wiping down the woodwork in the MH.
I noticed that the finish is nice but I'm thinking of applying some wipe on finish. I use to use boiled Linseed thinned just right with turpentine.
I don't think so, in the confines of the MH though. Can't imagine I would live long enough for the odors to go away or what they might do to other things.
The wood is quite handsome and a little better finishing would look great.
Anything out there that won't require a gas mask or fire extinguisher?
oldbeek
lancaster CA
Watco teak oil does a nice job. Very good for touching up dings in finish. Wipe on with a cloth. Instead of using screw cap, I punch a hole in opposit corner and seal it up with a metal screw. Screw cap will get locked up on first use.
1994 27sl Alpenlite, 2001 Dodge Cummins auto 3.54 stock
Mootpoint
Somewhere in North America enjoying the life!
Make sure to dispose of the rags that you use with Watco oil. It can spontainiously combust really easy. I know this from personnal experience unfortunately.
Other than that I swear by it.
Nothing sucks more than that moment during an argument when you realize you're wrong.
imgoin4it
Alamogordo, NM USA
Lemon oil polish available in most grocery stores.
Retired and loving it
Living in the Land of Enchantment
Traveling in 2007 Newmar KSDP
towing a Jeep Liberty
with a Blue Ox tow bar
campn4walleye
Central WI
That's what I used on our fiver's cheap wood. Made everything shine beautifully and smell fresh. Will use the same on our new TC.
2011 Adventurer 910FBS,Torklift tie downs,Fastguns & Wobbl-stopprs
2012 Dodge 3500 DRW 6.7L CTD, 4x4, LB,CC,6 speed auto,3.73 axle, General 17" on/off road
2008 Lund 1825 Explorer Sport,115 Merc,9.9 kicker,Torklift Super Hitch,42" Supertruss
USAF ret E-9&E-7
milo
4 Corners
Get a can of "Restore . A . Finish" and rub on em. It comes in the different finishes. I use the Oak on the TT & stick home cabinets. Then apply "Howard Feed-N-Wax" Wood Preserver, it's a Beeswax and Orange oil. Will make your cabinets look like new without stripping the the finish off em.
Milo
Janet(boss)& Milo 36 & 1/4 yrs 2gether
Retired Educators
Mona Mo 6 yr old Yorkie & (in spirit) our Beagle Buddy
13 F-150 Eco Screw HD 4x4 07 294RLS Cougar TT
Confidence is the feelin you have just before you fully understand the situation
Supreme Oppressor
Grande Prairie, Alberta
Until I had to do a repair, the only real wood in my fiver was the firewood in the front compartment.
Back when I had time to build & restore, I used to like to finish with tung oil. Not smelly or oily when dry. Note: "Pure tung oil" is tung oil; "tung oil finish" is not, and may not actually contain any tung oil.
2006 F350 6.0 diesel cc lb srw
2004 Jayco Jayflight 30.5BHS
Just Bob
SD/CT/FL/WY
Fornbys or Formbys.....great stuff. Don't know the correct spelling
