powderman426
ohio
Here'n'There wrote: Boy I wish I could remember the brand name of the hoses I have... I see them at RV stores once in a while. They are gray and advertise "triple the wall thickness" (or something like that) on the box. We are full timers and I have been using these hoses for over 2-1/2 years - no sign of fatigue or other weakness issues.
You should be able to google it.. matter of fact I think I will try and will report back.
Could you be talking about Camco?
They advertise heavy wall hose.
Ron & Charlotte
WD8CBT since 1976
28' Prowler & 05 Ram QC LB
I started with nothing and I still have most of it left
I never fail, I just succeed in finding out what doesn't work
thecampingman
Wilmington, OH, USA
Like Clay L I use Valtera's best hose. Over $50 for a sewer hose! Not even it can stand up to cats! They love to sink their claws into the soft vinyl leaving pinholes. I've caught them doing it!
So I put my Valtera hose inside a 4" black corrugated semi-flexible drain pipe I got from Loew's. (It's cheap) It also protects the hose from UV rays.
So far so good. I'd been replacing hoses twice per season. It's kind of a PITA hauling the corrugated drain pipe, but it'll flex enough to go into the bed of the truck.
'03 GMC 4500 Topkick with Duramax/Allison
'04 36' McKenzie Medallion triple slide
Cabover kayak racks w/18' touring kayaks.
Bicycle carrier on the front with a street bike & a mountain bike
Snowbird W/Ohio camper dock
Klueck
Thanks to you all for your great suggestions. We had a new piece of Rhino Flex overnighted to us, so we're good for now. We're in the Florida Keys, so there wasn't much choice for sewer hoses. I think we'll check camping world when we get back to the mainland.
mobilcastle
OH
I think the sewer solution is a great concept. I will consider it when the time comes.
2010 Heartland 3670RL Demco,dual panes,2-AC,
7000lb axles,G rated LT tires,38' high profile,
2011 Chevy 3500HD,Dually,D/A,LB,EB,4X4,
B&W Companion,GVWR-13,000
sonicsix
Jerry n' Cynthia
We have the red ones from Valterra. Still have the same ones after 2 years and still going strong. We have two 10' sections and one 5' section, as well as the 90 degree coupler that goes into the sewer drain.
stickdog
29.820224, 81.94542
We use: Smart Drain
9-11 WE WILL NEVER FORGET!
04 HitchHiker DA LS 33.5 RLTG
09 F350 CC DRW 4X4
John
“A good traveler has no fixed plans, and is not intent on arriving.” Lao Tzu
paulcardoza
Southeastern Massachusetts
Rhino-Flex...... Only time we had it fail was when I left it sitting against the exhaust pipe for the Aqua-Hot....... Grrrrrrrrrr...........
Paul & Sandra
New Bedford, MA
2003 Monaco Executive M43 DS2
hitchup
Fulltiming and on the Road.
Normally, we sit long term & hardpipe. Some RVParks even provide the pipe for us. But over the 2010-11 winter, we put our trust in RhinoFlex hose in MD. It also developed pin holes, but duct tape fixed it temporarily.
Since then, we're back to hardpipe & use the slinky only when sitting longer than overnight between projects.
2009 DRV Mobile Suite 38TKSB3 (38RSSB3)....our custom home w/2011 upgrades
2010 Ford F450 KR CC 4x4......his office
Working Fulltimers since 3/2005
"Shoot for the Moon! Even if you miss it, you will land among the Stars."
ASPENMAN
New Mexico
We will start full timing on 4/5. I just bought a Rhino Extreme sewer hose kit
from Camping World. "Won't dent - won't rust - extra protection from pin holes.
Write-up sounded good so we shall give it a try.
Look forward to learning & participating on this forum.
BLOGS:
http://rvpainter.blogspot.com
http://art4rvs.blogspot.com
31' Class C NEXUS Phantom 4/4/12
Pressure Pro TPMS
Progressive Industries EMS/Surge
WiFi Ranger Mobile
Cab over entertainment center
valhalla360
No paticular place.
Cheap walmart hose.
We are on our second one but that was because it froze solid in New Mexico last winter and it snapped when I tried to remove it.
We are usually on the move and hook up the hose mostly just to dump as opposed to snow birds who are stationary for months at a time.
Tammy Mike & the Bilge Rat (AKA: Diego)
Ford F250 7.3L
1997 Sunnybrook 27' 5er
1995 Gemini Sail Catamaran 34'
Full Time spliting time between boat and 5er
